Old 09-28-2016, 10:13 PM   #11
JackTuppVan's Avatar
Originally Posted by zuren View Post
Is there a suggested type of material to make this curtain? This is another feature I was looking to add.
GOOGLE "thermal curtains" , "blackout curtains" , "Insulating Curtains"
https://en.wikipedia.org/wiki/Blackout_(fabric)
Basically multi layered fabric /foam / rubber coated fabric like hotel curtains.
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 10-02-2016, 01:26 PM   #12
Shaggy's Avatar
I am rolling! Buahhhhhh!
2014 E350 EB Quigley 4X4 [HOONIVAN]
2014 FJ Cruiser
Shaggy is offline   Reply With Quote
Old 10-04-2016, 11:46 AM   #13
accrete's Avatar
we use a reflectix double layer sandwich in all our windows. They do two things for us (we have windows in slider and rear in our cargo 1500 awd cargo van)
1) privacy
2) lessen the cold transfer.
We don't think of them as doing much more than taking the chill or heat off the glass. And like others, our environment (in the PNW) is rather mild so sun is not much of an issue ; ) so the heat buildup is not much to concern ourselves with but there was a trip to eastern Oregon that I noticed I had to back the upper edges of the reflectix plugs away from the window to let the heat escape just in case.
Greetings from the Sunny Southwest, USA
2017 RAM Promaster Conversion. SOLD: 2010 Chevy Express AWD
Van Build Thread @ SMBForums
accrete is offline   Reply With Quote
Old 10-04-2016, 12:00 PM   #14
I made a sandwich of headliner material-reflectix-headliner material...about 1/2" thick total. Black on both sides, although that's mostly because that material was on the bargain rack at the auto fabric store.
Stays in the window openings pretty well, and provides quite a bit of insulation. The long term plan has been to sew a binding around the perimeter, but haven't got that far yet.
I used hi-temp spray contact adhesive (headliner adhesive) to glue the three layers together.
Old 10-12-2016, 12:58 AM   #15
wantahertzdonut's Avatar
I went a step further than boywonder and added a layer of Lexan to reinforce the insulation layer when I prop it up. The insulation is velcro'ed into the windows for easy removal when driving and is stuck up in about 3 minutes once I park. Blocks out light and heat on hot days. Haven't been out on a cold day to see how warm it stays inside. Headliner glue sticks the Reflectix to the Lexan, and I'm getting another can to stick headliner fabric to the lexan so it's just plain gray inside.
wantahertzdonut is offline   Reply With Quote
Old 10-14-2016, 10:34 PM   #16
I've got a window van I'm starting to think about insulation for the windows. I think I am going to permantely cover just a few of them to build cabinets over. If there is a concern about the reflectex damaging a window, would it be wise to maybe just put some headliner material facing to the outside so I don't have to worry about it?
1998 E350 EB V10 - Coming soon! MG Metalworks/UJOR 6" lift 4WD.
2011 Triumph Tiger 800XC
Backcountry Pursuit is offline   Reply With Quote
Old 10-20-2016, 03:01 AM   #17
caideN's Avatar
Any pictures?
caideN is offline   Reply With Quote
Old 10-20-2016, 07:49 AM   #18
what thickness polycarbonate (lexan)?........assuming around 1/16"...
donut: since you are in OC you are probably aware of A1 foam and fabric in Santa Ana...great place for auto upholstery supplies....
How are you velcro-ing to the windows?
Old 10-22-2016, 12:45 PM   #19
jpau00's Avatar
When I did my curtains I went to a large fabric shop (not the typical retailers) and bought the fabric I wanted and blackout material in the same quantity. I went with a flannel. It was just a matter of sewing the two together.
Unless you are having an upholsterer make the curtains, you'll want to keep the outer material not too thick. Otherwise it is too much for a standard machine to handle.
You could probably get a thin foam layer from such a shop as well and sandwich it between the two materials. Use a spray adhesive to fix it to the blackout material and leave a lip around so you don't have to sew through the foam too.
I still use reflectix for insulation, but the curtains are great for quick covering. Plus I could get the perfect camper van plaid.
Full disclosure, I don't know how to sew. I had my mother do it because no matter how old you are, moms rock.
jpau00 is offline   Reply With Quote
Old 10-22-2016, 02:02 PM   #20
[QUOTE=boywonder;185884]I made a sandwich of headliner material-reflectix-headliner material...about 1/2" thick total. Black on both sides, although that's mostly because that material was on the bargain rack at the auto fabric store.
QUOTE]
I did nearly the same thing. I did black headliner>reflectix>tan automotive carpet stuck together with high temp contact adhesive. I sewed folded black nylon webbing around the edges to bind them.
My thoughts were that I could put the black out for privacy and when it is cold out, keeping the lighter tan inside so it wouldn't feel so dark when the lights are on. If it is hot out the tan could go out for less heat absorption. I probably would use a tan headliner instead of the carpet if I were to do it again. I think my original plan was to leave the refelctix exposed on one side, but I had the carpet laying around so it got included.
Not seeing the foil from the reflectix on either side made it feel better inside and blacks it out well from the outside. We only have the front three windows. This is not the not the best picture, but here they are stowed away.
TeleSteve is offline   Reply With Quote
Vanzilla
Glenn P.
Ann the Van
Bongo
