Old 08-22-2018, 07:52 PM   #11
shenrie's Avatar
The sensor from my 03 sf axle slipped right into the 05 ff fseries axle I installed and didn’t trigger any cel’s. so apparently the tone ring matches up as well.
Old 08-22-2018, 08:02 PM   #12
MountainBikeRoamer's Avatar
Right on! Very cool. Does your axle have the single rear sensor (differential mounted) or the dual outboard sensors?
I might have mis-quoted the years by a year or two.
Mike T
___________________
'95 Ford E250 RB30 PH
Old 08-22-2018, 09:08 PM   #13
shenrie's Avatar
It has the single sensor in the diff.
Old 08-22-2018, 09:40 PM   #14
4-channel ABS (outboard rear speed sensors) started in 2005 on RSC models and went to all Econolines for 2008.
The 2005-2008 RSC axles are full floats, however adding a center sensor to an RSC axle would require a good machinist with big equipment. Being close isn't good enough for speed sensors.
FWIW - big rear brakes started in 2008 as well.
Old 09-21-2018, 06:28 AM   #15
225
225's Avatar
I paid $300 for my junkyard top. That's a good deal.
225 is offline   Reply With Quote
Old 09-21-2018, 08:02 AM   #16
shenrie's Avatar
^^^ not bad at all! that's a pretty nice shaped top too. whats the front look like?
our local pick and pulls charge $180 for a tv top off a typical conversion van, but you rarely see eb conversion vans.
