So, believe it or not, I still work on Polar Bear from time to time. The biggest current project is the installation of the furnace I bought from NomadCat back in 2011!!! The tank is mounted, the furnace is installed, and the gas lines are in. I need to cut a hold in the side of the van for fill access and wire up the electrical to finish. Well, I also have to run the heater vent tube, but that'll have to wait until I have the rest of the cabinent built.
Here the mounted tank and the furnace itself:
And today I put togther an enclosure:
I'm doing some organic shaped hand holds and supports around the inside. I am also including lots of holes for tying down gear. Here you can see what I've got so far in the back:
And here's the next support with a handhold that I also started today:
And a couple of pics for fun... Here's a snowy/foggy sunset the other day:
And finally, a shot from the shop showing how crowded things have been getting:
