Old 10-31-2013, 01:26 PM   #11
Re: Window AC inside van and vented through floor
Close up of one of the two 4-inch PVC ports to vent hot air out. I leave caps on while driving and parked at home. Or when I know AC won't be needed.
Old 10-31-2013, 01:31 PM   #12
This shows both outlet ports just behind AC. I meant to center them behind AC but design change after they had been cut on floor made them offset.
Old 10-31-2013, 01:36 PM   #13
A third port lets outside air into van next to AC so that conditioned air isn't wasted on condenser cooling.
Old 10-31-2013, 01:43 PM   #14
A side view of AC mounted on one rectangular piece of plywood. Note louvers and angle on opposite side of AC. Total weight is probably less than 50 pounds, making it easy to remove if needed.
Old 10-31-2013, 01:47 PM   #15
I drilled a hole in pan and installed overflow tube that discharges to one of the air vents. This keeps AC from overflowing in humid weather.
Old 10-31-2013, 01:51 PM   #16
A wider perspective of how air flow is separated. The electrical receptacle is behind AC. I didn't unplug AC for picture.
Old 10-31-2013, 01:57 PM   #17
Looking straight down at typical port with plug removed. I used one inlet and two outlets. I only screw them on hand tight and they don't come off.
Old 10-31-2013, 01:59 PM   #18
A port with cap on looking up under van.
Old 10-31-2013, 02:06 PM   #19
A couple of miscellaneous pictures. Hope the above is an indication of how I went about installing the AC inside the van so it can't be seen from outside.
Old 10-31-2013, 10:38 PM   #20
Nice work and neat idea!
