Been a few weeks...quite a bit done..but mostly little maintenance things..
ICP changed (injection control pressure sensor) as it would. It would restart fine after about 15 min of sitting but cut out within 2 min..and be hard to restart...more than 20 min it would be fine..less than 10 min it would be fine...weird...and it takes almost an hour to get to the thing..intake rubber has to come off...and lay on the motor...
And 2 weeks later the o ring on it starts leaking..back on top of the motor I go!!
Ordered the sunroof...it came in 4 days late...4...very....rainy...days....so carpet is soaked,thru the pad (see gigantic fan photo)
Finally got the last of the mounting Velcro done today...gotta,pick up 4 pieces for the other 2 windows and the small add on panel...but it went in and looks AWSOME!!
HITCHES on the front are amazing...and she tows the 14x7 tandem enclosed very well!! Needs a brake controller..
Pyro arrived on a slow boat from China..I gotta get a drill bit and a new tap set and it will go in tomorrow...now I can really see what's going on inside the cylinder heads..and look at exhausts and tuners...
It was a good day..new sunroof is pretty slick too!! Fully removable....
Sent from my VS987 using Tapatalk
