Old 02-08-2018, 09:30 PM   #11
Well then, it can be done. I'm not actually sure if it saves labor time if you don't have aftermarket bumpers to remove but it would be the way to go if you also wanted to rust proof or address anything else on the frame.
2011 VW TDI Golf for hwy fun
Old 02-08-2018, 09:43 PM   #12
Stock bumpers. Mostly I'm chasing fuel and oil leaks. I think the former is the fuel bowl and the latter the passenger side valve cover. Waiting for dye from Amazon to see if I'm right.
But I'm considering pulling the motor and completely going through it.
2003 Astro AWD
2005 Tacoma Access cab 4x4
Old 02-09-2018, 09:06 AM   #13
Bbasso's Avatar
My interior is rather elaborate and without destroying it we decided to pull the motor from the front.
But if the van was gutted, I would have gladly pulled the body off... which would have led to even more stuff/work lol
But the 7.3 is overall easy to work on in place, obviously some components aren't so and that's when you pull body off or motor out and get EVERYTHING DONE.
Rob.
Current:
And had three other E350s...
Old 02-09-2018, 12:27 PM   #14
[QUOTE=SteelheadJones;221348]Waiting for dye from Amazon to see if I'm right.QUOTE]
Please let us know how the UV dye works out, photos would be great. I've used it in the past, and leaks jump out, but I've never used it in a cramped engine compartment.
Old 02-09-2018, 12:36 PM   #15
Ha, oh man Arctic...I bought it because you linked it in another thread! Well, here's hoping...
2003 Astro AWD
Old 02-11-2018, 11:54 AM   #16
Oh yea, it will work for sure. Leaks jump out with a bright enough UV light. Add some to the fuel and engine oil too.
Biggie
Berta
Tan Hot Dog
Jsweezy
