Old 09-23-2012, 03:58 PM   #31
UJOINT's Avatar
Re: 7.3 or 6.0 for build platform?
We're also doing a lot of engine work these days. I have a full 6.0 upgrade that tackles all of the common issues and helps prevent failures down the road. We've done 5 in the last few months, the system is working great.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 12-17-2012, 10:23 PM   #32
Chris, what 6.0 upgrades you are doing?
Robert Britton
2000 Chateau 7.3
Chinook 4x4
robtbritn is offline   Reply With Quote
Old 12-18-2012, 01:10 AM   #33
Pschitt's Avatar
Hello robtbritn. You can see his kit down that page.
Old 12-18-2012, 08:22 PM   #34
UJOINT's Avatar
We delete the EGR cooler, clean the turbo, replace the turbo outlet hose, Clean the intake and replace the gaskets, change the coolant, fuel pressure regulator spring & filters. Add an EGT gauge that is mounted in the dash as well as a Scangauge to monitor a few vitals. And...... a custom tuner that adds some power and shuts down the EGR valve!
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
