Old 08-21-2015, 11:48 AM   #21
Bbasso's Avatar
Re: Electric cooling fans
Try adding a very large transmission cooler not in front of the radiator. I did that on my 2003 and it reduced engine temperatures drastically.
By letting all the transmission heat dissipate in to the radiator it doesn't cool as much.
Rob.
Current:
And had three other E350s...
Old 08-22-2015, 12:53 AM   #22
Viva's Avatar
Where would you put the transmission cooler then? I added a large trans cooler to my 1998 E-350 V10 (I tow), and immediately noticed that not only does it keep the transmission nice and cool, but .... the engine cooling fan runs more often. I had actually never heard it before it it kind of scared me the first time - that sucker is loud! I wasn't sure if it was because the trans cooler is physically in front of the radiator (blocking flow), or because of heat coming from the trans cooler. OTOH, it was a bit of a feat just to fit it in at all, much less moving it around (it's right in front of the radiator, where the smaller, original one used to be).
I don't think my engine is running any hotter, but that's because the engine cooling fan comes on more often to bring it back down (seems to come on at around 200º to bring it back down to 197º or so).
The trans never ran really hot, but like to see it nice and cool when towing (i.e. under 170º). I have sometimes now wondered if I should go back to a slightly smaller trans cooler to keep the engine cooler (sans fan).
Old 09-05-2015, 01:22 PM   #23
Bbasso's Avatar
Rather simple, it all depends on the size of the cooler you have.
I had a HUGE trans cooler and only one place underneath was able to accommodate the size... between the rear and spare tire.
Absolutely ludicrous looking and sounding but was extremely effective at reducing the temps.
It shaved off a whopping 50deg from the trans and 10-20 on the motor oil.
If you have a small unit with a fan built in, a location along the frame between the body would be a sweet spot.
But I give Chris full credit for that idea.
Rob.
Current:
Old 06-13-2021, 08:09 PM   #24
b. rock's Avatar
Originally Posted by JackTuppVan View Post
86Scotty ... I didn't Know how to attach files to PM so I'll post here . re: OEM hood vents and cowl induction hood .for heat extraction from engine bay .
Ok, I was looking at this thread contemplating aux fans but have to ask based on that pic - who makes a cowl hood for the econoline??
b. rock is offline   Reply With Quote
Old 06-14-2021, 09:50 AM   #25
Saw this on Ebay --
https://www.ebay.com/itm/Ford-Van-E3...-/263426351489
Also -- https://www.sarona.com/Ford/Econoline%20Van/All/Hood/
Expedition Portal -- https://expeditionportal.com/forum/t...s.80198/page-2
Old 06-14-2021, 09:55 AM   #26
b. rock's Avatar
Interesting, but usually the goal is to get air out - not in. I don't mind cutting in louvers but that cowl hood has my attention and google isn't providing much for results.
Old 06-15-2021, 06:11 AM   #27
Weltec used to make vented fiberglass hoods for the ford vans.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
