Old 04-22-2009, 09:57 PM   #1
Mild lift (wheels, suspension, body)
I'd like my SMB to ride a little higher. And I'd like to minimize rollover potential increasing.
Going from 225/75/16 tires to 245s raises the entire van 0.59 inches.
Would anyone recommend or have info on a mild suspension lift (say 1 inch) and a mild body lift (another inch?) I'm looking for relatively cheap, easy methods. Bigger tires alone don't work for me since they raise the entire center of gravity.
Thanks in advance.
Tom
Tom
Austin, Texas
1995 SMB E250
Old 04-22-2009, 10:57 PM   #2
Re: Mild lift (wheels, suspension, body)
I don't think you can do a body lift with the SMB built- I know that the dealerships have to remove the engine out the front instead of lifting the body off, I'm not sure why.. certainly where there is a will, but you want to check what all is dependant on the frame first.
Old 04-23-2009, 08:49 PM   #3
Bones_GSXR's Avatar
I am having National Spring make a 2in lift with custom coils and leafs. I did not want to go any higher as vans are pretty tall allready. The 2in will let me run 315's with out them looking shoved in the wheelwells.
Old 04-26-2009, 10:02 AM   #4
Thanks. I'll look into that. Is the 2" lift going to require modifications/adjustments to other components or just the springs and leafs?
Tom
Austin, Texas
1995 SMB E250
Old 04-26-2009, 05:35 PM   #5
neeemo's Avatar
I'd like to hear how it goes--although I'm already having trouble hauling my fat self in to the rig.
Tom (gravitationally challenged)
'02 SMB EB Q 4x4 Diesel
neeemo is offline   Reply With Quote
Old 04-26-2009, 11:27 PM   #6
Bones_GSXR's Avatar
I will need to correct the shock mounts in the rear, replacing them with mounts that look and function better than the Quigley mounts. aAs for the front I will be making new track arms as the will need to be a small amount longer. The ends will either be a teflon lined joint or polyurethane as teflon has a harsher ride. I am still doing the figures and will not be installing it untill sometime in July.
Old 04-28-2009, 09:21 AM   #7
Tom, just out of curiosity, why do you want your SMB to ride a little higher? My stock 4WD 2005 rides pretty high right out of the factory, and if I didn't have hoop steps, would have to work just to get in the door.
Tom
2005 SMB RB 50 4X4 w/ a 6.0 PSD
flyfisher is offline   Reply With Quote
Old 04-28-2009, 05:43 PM   #8
Tom
Mine is stock 2wd. Just want more clearance and a better look....and maybe bigger tires.
Tom
Austin, Texas
1995 SMB E250
Old 04-29-2009, 08:12 AM   #9
There is a used one with a good looking stance in classfieds:
http://www.sportsmobileforum.com/vie...php?f=7&t=2840
