Old 01-11-2015, 08:20 PM   #11
Re: Wheels and Tires
Thanks for the advice. The original owner must have swapped out the 16's for 17's as I do have 17's. Right now I have the hubcaps that look like rims meaning the plastic looks like the hubcaps are bolted on.
I think my first action is going to be to pain the current hubcaps with black plasti dip. Not that I want to remove the black, but it is either that or flat black.
If I remove the hubcaps, I can paint the rims, but I was hoping to make them look beefier than the stock rim.
I have NO intention of converting to 4WD. Not that I wouldn't want to, I just don't have a need for it with how I use the van. But the 4WD SMB's are HOT looking!
OneWagonHo is offline   Reply With Quote
Old 01-11-2015, 09:19 PM   #12
E350's Avatar
I don't remember if you said if they were steel or aluminum wheels? The reason I ask is that there is a product called POR-15, which I have never used, but is made for steel and, depending on what others on this forum say about it, you may want to consider:
http://www.por15.com/
And apparently Dupli-Color makes a spraypaint specifically designed for wheels:
http://www.duplicolor.com/products/wheelCoating/
Hey and OneWagonHo, I want to commend you for becoming a supporter even though you only have 9 posts! GoodOnYaMate!
(Then I noticed that I no longer have a supporter coin under my name. So, I contributed again and got this message: "You are already a subscriber, but thanks again for the contribution!")
Old 01-12-2015, 10:23 AM   #13
I have 16" wheels and have thought about getting 17" but tire are more limited. I don't have the bigger brakes but this is the one I'm looking at if I stay at 16" to replace my aging ATX Mojave's.
ATX Ledge 16x8 with a load rating of 3600lb. The ATX Mojave is 3100 lb. http://www.atxwheels.com/wheels/AX188/AX1886/techsheet
2011 VW TDI Golf for hwy fun
Old 01-14-2015, 10:59 AM   #14
geoffff's Avatar
Originally Posted by JWA
Is lower tire pressure advisable?
Lower tire pressure (assuming you are running the correct pressure for your tire size & load) is nice because it improves (softens) the ride, especially offroad. At least with the 4x4 vans, the front suspension is often pretty harsh -- with plenty of unsprung weight -- so squishy tires help.
Not quite black, but I recently switched to American Racing Mojave Teflon wheels, which are popular on Sportsmboles. I have 16" wheels (for more tire flex than 17" wheels with same tire diameter).
I spray painted black the alloy rims on my 2000 Jeep Grand Cherokee soon after purchase, and they haven't scratched yet.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 01-15-2015, 04:06 PM   #15
+1 on just spray painting the wheels black.
Toyo Open Country AT have been good for me, but wondered a bit at first. Tracks nice now.
2002 Chevy 3/4 ton Explorer Conversion Van with Quigley IFS.
TexomaPowerboater is offline   Reply With Quote
Old 01-17-2015, 11:28 PM   #16
Have a 2011 E350 and am also looking for wheels. Not doing 4x4 but may do a maxxlift 2" kit in front. What wheels will fit the van with out a 4wd conversion? What is the bolt pattern and hub bore and offset. Looking to go 17s with 265/70/17 AT's
chavez is offline   Reply With Quote
Old 01-18-2015, 06:49 AM   #17
bolt pattern for stock 2011 E350 (all modern 8 lug E150-E350) is 8x6.5" or in mixed units 8 x 165mm
VivaLaVida
Pschitt
Moby
new2tx
