02-02-2018, 08:25 AM
Originally Posted by rallypanam
If the pump is pumping it’s fine.
Likely a vacuum leak in the line.. and that will likely be the gray valve. I’d recommend starting there.
I had a nearly impossible time trying to source that gray shutoff valve locally last spring. Ended up having to get it from the Sportsmobile Store. I bought an extra just to have on hand.
02-02-2018, 08:41 AM
I have to respectfully disagree Robb. The pumps have rubber seals in them which do go bad. I had the exact problem described above with one. It would pump but cycle every few seconds. New pump, problem solved. No other leaks found.
02-02-2018, 09:46 AM
Many pumps have rebuild kits, or complete replacement ends available. Since the motor runs fine, why throw it out? Save some money and fix the one you have, a land-fill somewhere will thank you.
02-02-2018, 11:38 AM
Sure you did, sure you did.
02-02-2018, 01:20 PM
East coast, West coast throw down. Wagers on what the issue is....takers?
I say rip the whole entire damn system out and anyone but the Patriots start over! Nothing to it and would certainly solve the problem
02-02-2018, 07:10 PM
Well shit. And now the cycling is about every 20 seconds. Worked well for a shower today. Heading back to Duhrango Sunday with empty system and due to some medical issues will have lots of time to get it fixed. West coast.
02-03-2018, 09:29 AM
Whisper voice......"it's the pump". Rob was probably inebriated when he posted that. It was after noon. $50 and you have the satisfaction of knowing.
https://pantherrvproducts.com/shurfl...kaArelEALw_wcB
02-03-2018, 10:38 AM
The suspense is killing me.
02-03-2018, 11:10 AM
Where is the aforementioned "grey valve" located?
thank you
2007 E350 SMB (west coast build)
seasmith
2007 E350 Ford V-10
SMB Transformer Mod
All guts, no glory
02-03-2018, 12:05 PM
#20
If you have any kind of farm stores near you most of them carry similar pumps for spraying weeds and such.
