Old 02-13-2011, 03:38 PM   #1
mbachani's Avatar
CO2 Detector Expired
Its time to replace my CCI Controls CO2 Mod. # 3400 CO2 detector. I'm under the impression that they are no longer available.
Have any of you found a replacement that fits the same hole?
Thanks,
Bob in Tucson where it is 79 today.
2003 Ford V10 Quigley RB50
Bob
mbachani is offline   Reply With Quote
Old 02-14-2011, 09:30 PM   #2
mbachani's Avatar
Re: CO2 Detector Expired
Wow folks, looks like I really stumped everyone on this one.
No one has had to replace their CO2 detector yet?
Bob in Tucson
Bob
Old 02-14-2011, 11:59 PM   #3
cellularSTEVE's Avatar
I replaced mine a year or two ago and posted up the info on where to get it. It was the same unit. Try searching.
steve
Old 02-15-2011, 06:26 AM   #4
Mine died yesterday as well, and it's way out of date. I did some searching on the web and found some similar but not the same one. I'll do a search here now I suppose.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 02-15-2011, 07:03 AM   #5
mbachani's Avatar
Steve,
I tried the search function before I posted the question. No luck.
Bob in Tucson
Bob
Old 02-15-2011, 07:49 AM   #6
Try Safe-T- Alert , they have some that look close to the size of the CCI.
http://www.safehomeproducts.com/shp2...r/530/530.aspx
Old 02-15-2011, 08:32 AM   #7
mbachani's Avatar
Thanks Scalf,
I tried them before I posted and I may have to go with what they have. The face of their unit is about 1" higher and the back side which would be inserted in the wall is about .5" higher.
I'm just trying to avoid making the existing whole any larger, which really means trying to avoid doing any work.
Bob in Tucson
Bob
Old 02-15-2011, 08:34 AM   #8
yvrr's Avatar
I couldn't find any the exact same size but did find one slightly larger (Safe-T-Alert) and enlarged the hole slightly so that it would fit. That worked...
Jack
'01 Ford EB50p Quigley 4WD
Old 02-15-2011, 09:33 AM   #9
WVvan's Avatar
Hey Mbachani,
Here's the link to the posting Steve referred to:
http://www.sportsmobileforum.com/vie...p=17694#p17694
I think your original search might have failed if you were looking for CO2 detectors. It's a CO (Carbon Monoxide) detector.
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
Old 02-15-2011, 10:08 AM   #10
mbachani's Avatar
Hello WVVan,
You're absolutely right. But if I had a CO2 detector I'd know if my Power Tank had sprung a leak.
Bob in Tucson
Bob
Bruce
Sboring35
Behemoth
Besags
