07-10-2023, 12:05 PM
In my case, I added a third set of slides which stiffened up the whole thing and held the latches in position preventing them from releasing from vibration.
07-13-2023, 09:01 AM
How attached are you to that slide out cabinet? If the above suggestions don't help, consider converting it to a door and shelves. The issues you're describing are why we didn't go w a slide out.
Good luck.
07-13-2023, 10:10 AM
I'm starting with simply replacing the original latches and rebuilding/reinforcing the messed up particle board, and I'm taking arctictravller's suggestion of adding another slider, very clever. I'm still working on some concept to add a more positive stop to the whole thing. Oogs idea is interesting, too, but we'll see if we can make this work first. Thanks everyone!
07-13-2023, 04:38 PM
I replaced and adjusted my pantry latch so it holds pretty well, yet on really rough roads the pantry and another drawer would open, along with the fridge, so I created a slide in wooden brace that holds the pantry and drawer shut on rough roads.
Rob
'97 Ford E350 EB 7.3 PSD
Quigley, Sportsmobile
07-13-2023, 04:48 PM
So mine came straight from the factory with a snap strap. It worked and I guess was easier then redoing the front panel.
07-13-2023, 05:07 PM
Scalf, I was picturing something like that. Is that what I'm seeing in the upper left corner of the cabinet door? How's it work? Where'd you get it?
07-13-2023, 05:46 PM
It worked great, ready to hit the road snap it closed. The latched worked OK around camp. As I said this was made and put on by Sportsmobile. I don't have the rig anymore, so I can't give you a lot of details. They used some upholstery material, but I expect any webbing would work. Again they used their standard snaps.
After a couple of fixes involving alternate latches which were not sturdy enough in the long run I too made a slide in wooden brace. It may not look elegant but it always works.
07-14-2023, 09:59 AM
Boy wonder, you are too kind! Thanks
07-14-2023, 11:27 AM
#20
Questions- is there a standard size of the snap screws and covers SMB/Field uses on the interiors? Can you buy them with screw covers? Source?
Has anyone tried something like a glass retainer clip for something like this? Thinking out loud...
