Old 03-19-2019, 12:35 PM   #11
BrianW's Avatar
Propane tank: How to empty?
Originally Posted by 86Scotty View Post
Brian, I sandblasted and painted mine without even emptying it. I emptied it later to change a valve.
Wow, really? You’re braver than I. Anyway, I need to take it somewhere to have it done and I’m sure they wouldn’t touch it full.
Old 03-19-2019, 01:14 PM   #12
Originally Posted by SteelheadJones View Post
I bought a used Westy tank a couple months ago. Assuming I empty it can I grind/cut the existing mounts off and weld new ones on? Or am I just asking to blow s*&@ up?
It's never recomended to weld on any pressure vessel. At a minimum, if you do, I'd have it hydrostaticly tested prior to purging and refilling.
Old 03-20-2019, 01:08 AM   #13
What type of company does hydrostatic testing?
Hi, I’m Robert and I’m a vanaholic…
2003 Astro AWD
1999 E350 RB 7.3 cargo
2002 E150 RB 4.6 hightop van conversion
1999 E350 RB 5.4 Chateau
Old 03-20-2019, 09:47 AM   #14
gahamby's Avatar
Check with your local dive shop or fire extinguisher supplier.
Or your local supplier of propane and propane accessories.
'07 GMC 2500 6.0
Old 03-20-2019, 10:41 AM   #15
Agreed, I use to have scuba tanks hydro'd at the dive shop until I found out they sent them to the local fire extinguisher shop. It was faster and cheaper to take them there in the first place.
Old 03-20-2019, 10:44 AM   #16
Thanks guys, much appreciated.
2003 Astro AWD
Old 03-20-2019, 12:44 PM   #17
gahamby's Avatar
https://www.ebay.com/gds/How-to-Tran...5245456/g.html
try this, apparently once you have transferred all the propane you need to fill the empty with an inert gas/air.
'07 GMC 2500 6.0
Old 03-20-2019, 01:21 PM   #18
BrianW's Avatar
Thanks. Missed that it my research (a how-to on EBay: who knew?). Sounds like more than I want to mess with, so unless I can find a local dealer that is able to do it for me, I guess I’ll just be cooking all my meals for a week in the van to use up the propane :-)
Old 03-20-2019, 03:33 PM   #19
gahamby's Avatar
Could be worse. Work on some new recipes.
'07 GMC 2500 6.0
Old 03-24-2019, 12:34 PM   #20
pugslyyy's Avatar
Propane is non-toxic and I've always just vented it to atmosphere on the rare occasions that I've needed to empty a tank to remove it from the vehicle. It's really not practical to empty a tank and recapture the propane, since it needs to be stored as a liquid and comes out of the tank as a gas.
Remember that propane is heavier than air, so it runs downhill - it can pool in the bottom of a bucket, inside a sewer, etc.
When it comes time to refill the tank you need to tell the attendant that the tank has been open to the air so they can purge it before filling.
pugslyyy is offline   Reply With Quote
Campervan
Joerg
MoMo
skyrat
