Old 09-03-2015, 07:30 AM   #21
skyrat's Avatar
Re: Rebuilding the Day/Night shades with Wire
Originally Posted by daveb
I know what you're talking about. I wonder if steaming then folding closed and setting them in warmth to dry would work? Last resort might be an iron on a low setting but I'm just guessing. Have you ever contacted the company itself?
I haven't gotten that far.
Who is the manufacturer?
I like your idea of steaming, and drying. Because they seem to be a poly material they probably will not absorb moisture, which is a good thing if you are a shade in an RV... Once I get into this I will try and find out what the manufacturer recommends.
George ><>
2005 5.4L E250 RB50 4x4 SMB
2000 4Runner Limited 4WD
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
skyrat is offline   Reply With Quote
Old 09-03-2015, 11:23 AM   #22
I've never asked who makes the things. Maybe a shop that sells them can tell you or even suggest a good way to fix em.
Old 09-03-2015, 12:57 PM   #23
Specialty Window Coverings (574) 262-5190
Old 04-01-2016, 12:25 PM   #24
ANZAC's Avatar
By the way the new style cord tensioners are "JR 81945" and are easy to find at RV outlets and Amazon.
Sportsmobile-less.
Old 08-18-2016, 07:40 AM   #25
allenl's Avatar
These kits seems like the most economical option. Enough string and accessories to do 3 shades for $25. You pick the color.
Restringing Kits For Pleated Shades On RVs, Vans, Boats, And More Day Night Shade Restringing Kit
allenl is offline   Reply With Quote
Old 08-18-2016, 07:42 AM   #26
allenl's Avatar
I'll post up a review once I've installed mine.
Old 11-16-2016, 03:30 PM   #27
joey2cool's Avatar
Attached Key Point Sheet for day/night shade cord replacement based on what I learned by watching a local mobile blind repair service fix my barn door shade for $50. This includes a new idea on how to solve the problem of a stripped thread when reattaching a cord tensioner to the interior door cover.
Name:	Key Point Sheet - Day-Night Shade Cord Replacement.jpg
Silver Bullet
joey2cool is offline   Reply With Quote
Old 02-07-2017, 08:28 AM   #28
joey2cool's Avatar
Another tip to address stripping plastic door panel sheet metal screw holes:
Wrap the point of the screw with plumbers tape so that it fits snug in the widened hole.
This turned out to be much easier than any other solutions posted to date.
Cheers!
Silver Bullet
Old 09-15-2018, 04:59 PM   #29
Mine are starting to fail occasionally (just had second one break in about 6 months). Rather than re-string/repair I am thinking of replacing all with new units.
Does there happen to be known part numbers or such to make sure one can order correct sizes / units.
Or, if one has to buy through measurement is it correct to assume one needs the exact measurement of the shade width and length when down (ie: versus window dimensions or other)
Van is standard 2005 EB50 layout/windows w tan interior.
Thanks in advance!
rarrace is offline   Reply With Quote
Old 09-21-2018, 07:53 PM   #30
Orv
This thread really helped me out today. One of my shades needed restringing after the cord snapped. I ended up using bead wire -- my first choice would have been 50# fishing line but for various reasons it was easier to get bead wire. It works great now, smoother than the one that hasn't broken yet.
I don't have the plastic cord locks -- on mine the cords wrap around another channel below the window, and join with a second spring. They're otherwise the same, though, and the diagram was a big help. Until I saw that I just couldn't visualize how they worked.
ADVMOBL
Botchan
Ford
fabtechmfg
