05-31-2022, 03:08 PM
#411
Originally Posted by 1der
re: ARB sets - I only did that for one run. You can buy a full set, use the front and rear brackets and hang on to the middle bracket and hardware in case you want to move to a Fiamma awning in the future.
I use these with an 8' ARB awning. Drill the 2 mounting bolt holes into each bracket face and you're good to go. I use all 3 brackets. I figured I might as well.. no harm done and it adds even more security. My ARB awning will not be flying off anytime soon!
06-17-2022, 06:56 AM
#412
Just wanted to report the new awning brackets arrived here in Maine on Wednesday eve. I've been sitting on the Fiamma awning 1der sent a month ago, and I am excited to give installation of the brackets and awning this weekend. They look rugged, great hardware, and the instructions and video make it look possible for this amateur.
06-18-2022, 04:41 PM
#413
Brackets and awning installed the detailed video made this install easy going
Thanks Ray!
2000 Ford RB30 PH 2WD -- Eagle Rock California
06-18-2022, 06:27 PM
#414
Very cool stiggs!!! You did have the SMB holes present in your rig, right?
Thanks Ray!
06-18-2022, 06:34 PM
#415
No holes until the ones I put in to install the screws that came with your brackets.
07-06-2022, 03:00 AM
#416
In for information on fitment with tufport hightop as well. I'm getting the hightop in about a month and currently have the Fiamma 45s on my rig. Would hate to get rid of it if I can't mount it on the gutter with these brackets.
When will these be in stock again?
09-14-2022, 05:45 PM
#417
If allowed, does anyone have a third (middle) bracket they don't need, that I can buy off you?
My current setup has a flat middle, and offset ends, which bows out my ARB awning in the middle. While it worked fine with the soft case, I just bought a hard case and there's too much pressure on the middle bracket for it to work.
Thanks! Nino
2010 E350 SMB
09-15-2022, 01:39 AM
#418
Thanks! Nino
2010 E350 SMB
Hi Nino, please send me your contact info at cs@BlingMyRig.com so I can give you a call to discuss what is going on. Thxs, 1der
09-15-2022, 01:48 AM
#419
Hi Ldo, the TufPort top is a nice top. I believe from the pictures I have seen that gutter mounting will be difficult without notching the bottom edge of the fiberglass.
I have also been told the TufPort tops have a wood reinforcement that runs down the side of the top. Personally, I would have no issues mounting my awning to the side of a fixed top. It will require only two mounting points about 18" in from each end, and a wedge to compensate for the curvature of the fiberglass. Through bolted with a backing plate and use of a polyurethane or lap sealant around the holes will provide a waterproof connection.
Post up some pictures of the top to gutter interfaces at the B pillar, just behind the side cargo door and about 8 ft back from the B pillar. Those pictures will give me an idea if the gutter mounts will work.
12-07-2022, 03:12 PM
#420
Is there a reason why the middle bracket is shorter and doesn't have the bent profile to hook onto the track like the two other ones?
I was hoping to bolt the Fiamma aluminum brackets to these and avoid additional drilling into the awning.
