Old 02-20-2015, 01:03 PM   #11
clubnobbie's Avatar
Re: Ford E-Series Van HID Projector Retrofit lights
Sending email!
__________________________________________________ ______
2003 E350 15-Pass Zombie Van • 7.3L Diesel • Quigley 4WD • CCV Mid-Pro Pop-Top • Urban-Coated Gray • Fiamma Awning • Aluminess Nerf Bars • Wind Deflectors
clubnobbie is offline   Reply With Quote
Old 02-20-2015, 01:13 PM   #12
REDOVAL's Avatar
Originally Posted by shenrie
Originally Posted by JackTuppVan
I currently have the commercial style sealed beam headlights. Are these composite headlights a direct replacement? Will it be necessary to make any modifications to the headlight panel or will i need to source any additional parts when converting from sealed beam to composite?
youll need the composite headlight pigtails, but everything else is compatible.
These come with my light kits if you need them.
Scott
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 02-20-2015, 01:25 PM   #13
mikracer's Avatar
Don't you need to replace the grill and other pieces behind the grill?
Old 02-20-2015, 01:32 PM   #14
REDOVAL's Avatar
Nope, the original header panel comes prepped from Ford to be compatible with both versions. If you are concerned and want confirmation, post a photo here and we will have a look.
Scott
Old 02-20-2015, 03:38 PM   #15
Viva's Avatar
Never mind - answered my own question.
BTW - these look slick!
Old 02-20-2015, 05:16 PM   #16
Can you provide a link to the proper HID kit? There are so many, it's a bit confusing. Thanks................
Old 02-21-2015, 12:07 AM   #17
Can you get a projector HID kit the newer front lights 2008-2014 Ford e350?
2008 Yellow Ford E350 6.0 diesel eb50 4x4, Front E Locker, Asheville Eng Rebuil 20th @ 261miles, ARP Studds, 200amp Alternator, Performance Aluminium Radiator, OnBoardAir, RoadmasterActiveSuspension, Front & Rear Aluminess with Spare Tire Carrier, Aluminess Roof Rack, Titan Aft 30gallon Fuel Tank.
Sheriffdoug is offline   Reply With Quote
Old 02-21-2015, 09:40 AM   #18
mikracer's Avatar
I would avoid the $20 kits on ebay and the like because the ballasts are usually inferior and don't put out the power needed to fully ignite the bulbs. The results are low light output and blue tinted lights. I bought a set and I threw them away.
I bought these morimoto bulbs... http://www.theretrofitsource.com/compon ... OizeihwFUQ
and ended up with these ballasts... They are bigger, but they are solid and work great. http://www.amazon.com/gp/product/B00301 ... UTF8&psc=1 (the standard 35 watt ballasts).
Old 02-21-2015, 11:53 AM   #19
REDOVAL's Avatar
You can use any 35 watt H1 HID kit with these lights I provide. If you choose the Morimoto items, you will pay a ton of money (5x more) for more or less the same thing. I have had very good luck with the budget HID kits. When combined with the proper bixenon relay harness they have no problems lighting up and not flickering. I have had good experiences with the following items and I recommend them for those interested in keeping a tight budget:
http://www.ebay.com/itm/171221706222?_t ... EBIDX%3AIT
http://www.ebay.com/itm/Digital-H1-HID- ... 266wt_1362
One thing to consider, the higher the color temperature of the bulb (bluer looking) the less available output this setup will provide. The 4300K bulbs offer the most output and are a nice white color compared to the stock halogen bulbs.
Scott
Old 02-21-2015, 11:59 AM   #20
REDOVAL's Avatar
I can do the projector retrofit on the newer lights but the cost will be in the $600 range as the lights are very pricey. If anyone is interested in these, send me an email and we can talk.
Scott
Stredbull18@gmail.com
Faultine
rizzabove
Campervan
Joerg
