Well we made it through January so it’s time for another update on some of the products available through Vantage Optics and a new coupon code. Apply
VOFEB2021 and save
10% on any purchase through the end of the month.
In addition to our headlight kits available for Ford and Chevy vans (links below) we now offer several other new products that may or may not catch your interest!
Ford Lighting Options-
https://www.vantageoptics.com/shop/F...Kits-c25728076
Chevy/GMC Lighting Options-
https://www.vantageoptics.com/shop/C...ghts-c25761007
Ford Econoline Underhood Service Light Kit-
https://www.vantageoptics.com/shop/V...Kit-p276199702
Ford Econoline vans from 1992-2007 (08-current kits in process) do not have any provisions for light in the engine compartment. If you've spent any time around vehicles you are aware that they never break or need work when it's most convenient! This kit aims to provide an easy to install light kit that provides plenty of usable output with a push button on/off switch. As an added bonus this kit allows for an optional remote light kit to provide light exactly where you need it on the vehicle.
Features-
-Application specific kit (universal also available soon)
-High output LED light with aluminum housing
-Push button on/off switch
-All wiring/connections provided
-Fused power lead for protection against over-current
-Minimal modification needed to install
-Single Weatherpack lead for system expansion
-Optional remote Profile magnetic work/camp light assy
Vantage Optics Remote Service/Camping Light Kit-
https://www.vantageoptics.com/shop/V...Kit-p283641007
Add bright usable light where you need it with this clever add-on kit. With its magnetic backed Profile LED light and long extension lead you will be able to place the light in the optimal location to make your repair or set up enough light for camping applications. Current consumption is very low and will last a long time on your current vehicle battery power before having issues.
Features-
-Profile magnetic light assembly (white light)
-12" fused battery lead (inlcluded but not shown at this time, compatible with other Weatherpack connector items)
-Weatherpack connectors provide a durable joint
-Optional cigarette lighter outlet harness allows use without battery connection (assuming the outlet is hot when the vehicle is off)
-Enough cable length to provide access anywhere on your vehicle
-Easy to store via the magnet or optional Molle style pouch
Vantage Optics Universal Dust Light Kit-
https://www.vantageoptics.com/shop/V...Kit-p276476366
Offroad rigs and vehicles and traveling in low visibility conditions (snow/fog) can benefit from a rear facing amber light assembly (same concept as fog lights). The amber-colored light cuts through dust and inclement weather to make your vehicle seen and noticed before accidents happen. This unique kit aims to provide universal use in most any vehicle that has a standard cigarette lighter port available. The light is intended to be mounted to the inside of the vehicle's rear window using the Ram Mounts®️ Twist-Lock suction cup mount. Providing the window is properly cleaned prior to mounting the light assembly it will stay put even in very rough conditions.
Light Options-
-Baja Designs®️ S1- amber light features a wide cornering lens (2375 lumens)
-Diode Dynamics SSC2- Pro and Sport models with an amber combo lens (777 lumens Sport, 1858 lumens Pro - measured)
-Whelen Ion (possible in the near future)
Features-
-Steel-it®️ coated steel bracket (two configurations available based on window slope)
-Ram Mounts®️ Twist-Lock suction cup mount
-Weatherpack or Deutsch Connectors depending on the light
Benefits-
-Universal use on any vehicle with a rear window
-Non-permanent installation
-Secure theft-proof mounting inside the vehicle
-Super bright Baja Designs or Diode Dynamics light
-25' length fits even the longest vehicles
-Low current draw (~1.7A)
-Includes an adapter for use as a cigarette outlet extension
-Make any vehicle a chase rig for offroad racing
Options-
-Optional Profile magnetic service light assembly uses the same wiring for remote use
-Optional sealed and padded carrying case protects your investment when not in use
Availability-
These kits are made per order at this time and take about 1-2 weeks to process as we ramp up production. Thanks for your patience!
VO 3156 LED Reverse Light Bulbs-
https://www.vantageoptics.com/shop/V...lbs-p131966176
Replace your incandescent 3156 bulbs with these bright white LED replacements. They simply pop in and work great to add more light wherever you need them. We use them as reverse bulbs and find them to be a great improvement over the OEM units. These work well in both OEM and aftermarket taillight housings
VO Big 3 Cable Kit- 97-14 Ford Econoline Gas Engines-
https://www.vantageoptics.com/shop/V...nes-p219068555
Optimize your 97-14 Ford Econoline gas engine charging system with this kit. Modifications to the OEM battery terminals are required to install the kit, but they can be done with simple hand tools.
This kit allows for enhanced alternator to battery connection and engine block to both chassis and battery ground connections using oversized USA made 2/0 Excelene welding cable. Most electrical system components in the van platform are woefully undersized preventing proper alternator efficiency and premature battery failure. The addition of the military terminals allows connection to the battery for additional components in a very efficient and aesthetic way to reduce wiring clutter.
Fitment-
97-14 Econolines with the 4.6/5.4/6.8 Triton engines
Kit contents-
1x 2/0 Alternator to battery cable (USA made components)
1x 2/0 Engine block to battery cable (USA made components)
1x 2/0 Engine block to chassis cable (USA made components)
2x military style battery terminals
1x clamp
2x bolts to secure ground locations
Disclaimer- Installing this kit on your vehicle will provide a direct connection from the alternator to the battery. Any and all ill effects arising from the improper installation of this kit lie solely on the buyer and installer.
Scott Thompson
Vantage Optics
vantageoptics.com
Vantageoptics@gmail.com
