Hey gang,
Swapped rear axles on my 2006 from the factory semi float to a 99 rear axles full floater.
After the swap ABS light came on.
See attached.
Ford mechanic ground the brown wire and applied 12v to the red wire. Pump motor ran. So I believe it’s the ABS module. See attached diagnostic procedure.
Ford doesn’t make these anymore so I’m limited to used, reman and possibly aftermarket.
Has anyone resolved this issue before?
Tried sending in your module for a fix like a place linked below?
https://www.upfix.com/product/ford-e...epair-service/
