Old 04-01-2019, 02:20 PM   #11
Here is a video that might be an option.
https://youtu.be/x_fqq4w9HBg
Steve_382 is online now   Reply With Quote
Old 04-11-2019, 01:07 PM   #12
Otter's Avatar
Yakima Kayak loading
Since this thread’s been revived and so many people run into this problem, thought I’d add my $.02.
I don’t have a poptop (yet) but my rig is tall, I’m 5’ 6”, and not very strong. Had to figure a way to get my kayaks and canoes up there without any help. So I installed four 66” Yakima bars and put one as far back as I could get it. You use that rear bar to roll it on (No need for those fancy rollers... the bars are slick). I stand the kayak on its tail end on a blanket and rest the bow on the back bar. Pick up the back end and roll. It doesn’t take much to get it to tip and bam, down onto the bars or kayak saddles. The taller you are, the easier this will go. I use a camping step stool for the first step, then a hitch step, and finally, the van opening. I use one of those “grabbers” to pull my straps over the top using the stool or barn door/passenger door steps. Getting it down is a piece of cake, more gravity on your side.
I like the looks of those Yakima Showboaters, but you still have to be able to reach, and now you don’t have gravity on your side. I’ve been carrying kayaks around for 40 years and tried every darn way till I finally settled on this one. It’s cheap and easy. And if you need more height, get yourself a skinny step stool to hide inside some nook or cranny.
Old 04-11-2019, 01:11 PM   #13
Otter's Avatar
P.s., with two people, you could do this no matter the height. Tie a line to the bow, throw it over the van hood and have the second person pull tight. They can get it up there safely without a whole lot of effort while you’re lifting up to your limit out back.
Old 04-11-2019, 07:20 PM   #14
The thule hullavator work great. I've been using them for several years to load outrigger canoes. They make it a one person job
2006 E350 4x4 on 35's plus a rack
primitive is offline   Reply With Quote
Old 06-05-2019, 01:41 AM   #15
Looks like a good solution, not sure how it would work on a high top, but maybe a step ladder?
Wandering Bob
Currently, living in Alaska til I finish The Rebuild, then full-timing it...
2002 Ford EB 250 SportsMobile
Salem Kroger 4x4 Grrr (edit), fixed and drives like a dream!
WanderingBob is offline   Reply With Quote
Old 06-05-2019, 07:04 AM   #16
Fitz's Avatar
Otter and I use basically the same system. In my case the rear load bar is 8'-10" off the ground, thus the step stool he mentions is a requirement for me.
I'll let pictures tell the story.
KN6BJX
