Old 03-25-2014, 11:20 AM   #11
Re: Removing Penthouse
I started this project yesterday and it kind of went okay. The new bars didn't exactly 'slide' into the U tubes. I ended up taking the rear bar out of the van in order to be able to hammer the pieces in. I got those 2 in and called it a day. I had the U tubes pretty staight but the new bars fit so tightly. I used some grease to help but I don't think it did much. I think the main problem was the seam in the U tubes made the clearance too tight. I'm hoping the front tube will go a little better now that I know what I'm in for. I will take that one all the way out of the van also and hopefully fix a water leak from the top when I put it back together.
Old 03-25-2014, 02:06 PM   #12
Buffalo: Are your new tubes seamed or DOM (drawn over mandrel-seamless)?
Old 03-25-2014, 02:57 PM   #13
The new tubes I hammered in are DOM. The SMB U tubes have seams.
The new ones are 3/4 inch and appear to have enough clearance to easily slide in. I think the friction is from the seams on the SMB ones? Did you have that issue also? Any tips or advice for the other 2 I have to do still?
Old 03-25-2014, 03:01 PM   #14
My tubes went in rather easily, no grease/hammering required......although my SMB tubes appeared to be straight......can you put a straightedge on your SMB tubes to verify that they are straight?
Old 03-25-2014, 03:36 PM   #15
I did get them pretty straight before I tried. One of the new tubes slipped in maybe 10 inches or so and then it got tight. So even then it wasn't to the middle where the bends were. I even tried filing down the inner edges of the drill holes for the bolts before I tried.
I guess for the next one I will just double check that it is as straight as can be. I'll find something to use as a straight edge.
I'm just not looking forward to all that hammering again! I cut the new bars to 56 inches and ended up cutting off about 1 inch from the end where it was mushroomed.
Old 03-25-2014, 03:56 PM   #16
This thread is scaring me, since I now have a heavy rooftop box and rack on my top, and I recently cinched out four links. SMB Indiana told me 4 was ok but no more without additional strengthening. Also, it's a bear to lift, but I plan to rarely if ever attempt it with all of that stuff in my box. I usually pull out stove, chairs, and sleeping bags first. Anyway, I wonder if very many people have bent penthouse bars and how exactly?
Sorry for the distraction. Intriguing stuff though.
Old 03-25-2014, 04:09 PM   #17
After having it all apart now, it is kind of scary. It all relies on those little pivot bolts and the same size bolts at the ends of the U tubes. Definitely want the stongest ones you can get.
I'm not sure how mine originally got bent. I got the van and the rear tube had a bend in it. The van came from Alaska so my guess is snow. After I straighened it, it bent again from just use. The only thing on the roof is a small solar panel and it is all the way at the front of the top.
I'm glad you mentioned 4 links though. I had taken out 2 before and have been wanting to try for more. So when it goes back together I think I will try 3 first but probably go to 4. I would like a roof box up there also.
I will also either be buying or making the 4 corner supports for when the top is up.
Old 03-25-2014, 08:42 PM   #18
It's not very pretty, but I just used two 2x4's. I think they are right at 30" long. I put one on each side right in the middle instead of at each corner and it feels pretty good and stable that way. I have noticed even with the 'regular' stuff pulled out of my box it is still really hard to lift. I was surprised after 4 links and also adding 3/4" blocks to the lift assist springs in the rear.
Old 03-25-2014, 08:51 PM   #19
While you have it apart, you may want to consider going to 5/16" dia shoulder screws for the various pivots. It's a big improvement in many ways over the stock SMB 1/4-20 bolts.
Old 03-26-2014, 08:53 AM   #20
Thanks guys! I will for sure get the larger bolts you guys have mentioned before and the 2x4's are a good idea too!
