Originally Posted by PeasBugs
Digging up an old thread here. For those of you that use the Memory foam or something like it on the penthouse, do you leave it on the bed when you close the penthouse? And for those of you that leave your bedding on the penthouse bed when you close it how do you get the back J hook through the bedding to latch it down? I just bought the Memory foam from Costco and I am having difficulity closing the rear J hook, the foam is in the way.
Thanks
Also have the 2" foam cushion. I had to cut mine to fit the one piece sportsmobile bed so it doesn't get in the way of the J hook.
I had to remove the foam bed out of it protective cover and then I had to use a new sheet cut to size, sewed it back up after I cut it to fit.
It was a pain to do it but it sure is comfy now.
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
