Velogeo - PSE Wind farm
Login FAQ
Register
Sportsmobileforum.com
An online forum community for the owners, admirers and fans of Sportsmobile vans and Sprinters, new and old. Share photos, advice, discuss modifications, camping or buy & sell. Anyone who owns, has a passion for, or just curiosity about SMBs, come in!
The time now is Sat May 18, 2013 5:39 pm
Post new topic Reply to topic  [ 7 posts ]
Author Message
Support Bronze
Offline
PostPosted: Thu Nov 08, 2012 7:37 pm   Post subject: Opinion wanted on this solar panel
Hi all,
A local guy is selling a number of these "Trina" 240-watt solar panels as refurbs at $120 each. I was thinking of getting one for my SMB, but honestly don't know the first thing about spec'ing a panel, other than what I've read on the forums (consensus seems to be to get at 125 watts).
Any advice would be great. Here's a link to the panels: http://www.solarelectricsupply.com/Sola ... 0DA05.html
Back to top
Profile
User avatar
Admin IV
Support Platinum
Online
PostPosted: Thu Nov 08, 2012 8:51 pm   Post subject: Re: Opinion wanted on this solar panel
You might ask the seller if it has a warranty when installed on a RV. I'd also want to know if it can be tied into a RV solar controller...there is no voltage specs (that I saw) Other issues would be how to mount it. Seems the RV type panels are designed to be bolted to a vehicle. That said maybe its a good deal???
___________________
Contributor AutoRamblings..............AutoRamblings web site
Sportsmobile, Not Your Standard RV About Sportsmobile's (an online article)
Back to top
Profile
User avatar
Support Bronze
Offline
PostPosted: Thu Nov 08, 2012 10:01 pm   Post subject: Re: Opinion wanted on this solar panel
That is a high voltage panel and is not compatible with RV 12v solar controllers. I have a Solar Boost 2000e and the recommended max open voltage (VOC) is 24v. That panel puts out 37.5 VOC.
All solar panels are made for outdoor use so I wouldn't worry too much about RV ratings, especially if you can find something for $125, just my opinion.
Solar Boost 2000e data sheet
http://www.blueskyenergyinc.com/uploads/pdf/SB2000Edatasheet.pdf
___________________
2006 E350 6.0PSD 5R110, SMB 4X4, RB-50 layout, ARB lockers front/rear, AMP steps
Back to top
Profile
Support Bronze
Offline
PostPosted: Fri Nov 09, 2012 8:48 am   Post subject: Re: Opinion wanted on this solar panel
Thanks guys! Amps, volts and all that gets me confused sometimes. I'm pretty good with wiring stuff up, though.
I also found a 24v panel locally on Craiglist for around the same price, so maybe that would be a better war to go (or, of course, a 12v one).
Back to top
Profile
User avatar
Admin IV
Support Platinum
Online
PostPosted: Fri Nov 09, 2012 11:44 am   Post subject: Re: Opinion wanted on this solar panel
Actually at one time Kyocera was one of the few companies that offered a warranty on their 135 watt panels if mounted on something mobile. Looks like nobody (at least I couldn't find one) will warranty them now if installed on a vehicle or boat. Of course you don't have to tell them where they're mounted :b1: One thing about glass panels is they have been time tested but they can break. I shattered one of mine :b7: but hopefully that won't happen again.
I wish they would sell semi flexible panels at a reasonable cost. Unfortunately my flat walkable Solars did not last very long and was a huge mistake money wise on my part. Everything semi flexible I've seen on the market has a beaucoup price.
If your goal is to just keep your batteries up and charged for maintenance, a small 80 watt panel with a good mppt controller will do fine but having the ability to supply a positive charge to your house battery system depends on your daytime load usage and how large and how deep you've taken down the battery system. Seems that a 130w panel is a reasonable size for a SMB when comparing a cost to preformance value. YMMV I have twin 135's on my van.
___________________
Back to top
Profile
Support Bronze
Offline
PostPosted: Fri Nov 09, 2012 3:51 pm   Post subject: Re: Opinion wanted on this solar panel
I'm mainly looking for long-term battery maintenance while parked in my driveway to keep the batteries charged up, as I can't keep it plugged in all the time. My driveway gets full sun for over half the day, even in winter. I figure I either invest in solar or keep investing in replacing dead batteries! The charging/power while actually camping is secondary, although also very desired.
Back to top
Profile
User avatar
Admin IV
Support Platinum
Online
PostPosted: Fri Nov 09, 2012 4:28 pm   Post subject: Re: Opinion wanted on this solar panel
I'd at least prepare for adding to your array if you go small. Wire for it and purchase a large enough controller to handle future needs. It's nice to be able to supply the refrigerator and still have some power left over while the van sits.
___________________
Back to top
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Dango and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
