Old 09-15-2015, 05:58 PM   #1
Ford Transit 4x4s on the lot.
Looks like Newberg has about 5 of these on their lot right now. Prices on a couple of them were just under $50,000.
http://newbergford.com/inventory?Body=V ... rgo#popup2
Old 09-21-2015, 08:55 PM   #2
ctb
ctb's Avatar
Send a message via AIM to ctb
Re: Ford Transit 4x4s on the lot.
How much for the plastic surgery to make it look like an Econoline?
'13 MDX 'BigBlackmobeebs'
'01 Lexus 430 LS 'Luxobeebs
'20 Tacoma TRD OR 'Tacobeebs'
ctb is offline   Reply With Quote
Old 09-21-2015, 09:35 PM   #3
gcvt's Avatar
It's no Promaster but it ain't pretty. Red isn't its best color.
Greg
New van: 2003 E250 EB10
Old 09-21-2015, 10:52 PM   #4
Didn't regret my decision on the E series over Transit. Look does matter.
Tienckb is offline   Reply With Quote
Old 09-22-2015, 06:00 AM   #5
Angry Snoopy.
Old 09-22-2015, 07:45 PM   #6
Does anyone know who does that 4x4 conversion and does it have a low range?
DesertDan is offline   Reply With Quote
Old 09-22-2015, 07:48 PM   #7
Quigley and Quadvan. Supposedly tx case will be from F150.
Old 09-22-2015, 09:27 PM   #8
Jeffrey's Avatar
It may be 4x4 but it just doesn't appear to be an actual off road vehicle. Kind of like the all wheel drive SUVs that do better on snow and some mild rough roads.
Old 09-22-2015, 09:30 PM   #9
MadScience's Avatar
Originally Posted by 86Scotty
Angry Snoopy.
I'm not sure I'll be able to un-see that. -- Thanks.
There is a lot to be said for a larger hood and better access to the mechanical bits. It's a trade-off I'll make sooner or later, not sure if it'll be a sprinter, transit or something else. The ability to reasonably lift and put bigger tires on it will drive much of my decision.
Old 09-22-2015, 09:40 PM   #10
MadScience's Avatar
It's certainly a unibody, but it does probably have modern traction control, which goes a very long way in keeping a vehicle moving along the path you want it it. Not sliding into ruts regularly means a lot less clearance and articulation is required. It can also mean that lifting a single tire without lockers is actually not an issue.
I'm very curious if lifts will become available for it or the 4x4 sprinter. I think I can live with a unibody, I actually want modern traction control, but I do feel like I need at least a 33" tire, though independent suspension probably means I don't even need quite that big a tire.
Yes, I'll miss the monster aspect of my van, but I'll gain a lot of safety and hopefully real world performance, even on trails. -- That said, I don't think these vans are there just yet.
Miss Piggy
graybeard
Rex
Tomboy
