Old 05-03-2014, 03:54 PM   #1
WVvan's Avatar
Uh-Oh, I think Hal is intercoursed
So I go to start Hal a couple days ago and the starter wouldn't turn the engine over. The starter sounded OK but it sounded like the engine would start to turn over but then just stop. So must be the starter I thought.
Just put now put on a new starter and when I went to turn the engine over there was a loud BANG and violent shudder. I instantly turned off the engine and looked under the van to see oil pouring out.
Got the drain pan under there but not soon enough. One advantage of having cats. Big bags of cat litter.
So does this mean what I think it means (new engine needed)?
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
Old 05-03-2014, 03:59 PM   #2
BajaSportsmobile's Avatar
Re: Uh-Oh, I think Hal is intercoursed
Sounds like you had a "Hydrolocked" cylinder. Cylinder either filled with coolant (leaking head gasket) or fuel (leaking injector). Because you can't compress a fluid; when you cranked it over, something had to go bang. Perhaps a rod...
Old 05-03-2014, 04:01 PM   #3
No bueno
Sounds like possibly a cylinder was hydrolocked. Might have cracked the block or lifted the head pushing past the hydrolock.
What motor do you have?
Old 05-03-2014, 04:01 PM   #4
WVvan's Avatar
4.2L 6-cylinder
WWW.WVBIKE.ORG
Old 05-03-2014, 04:04 PM   #5
Coolant. Appears to be a common problem: http://forums.anandtech.com/showthread.php?t=1858066
Old 05-03-2014, 04:49 PM   #6
WVvan's Avatar
OK, assuming the worst, any remanufactured engine swap out advice? I'll definitely be farming this job out.
WWW.WVBIKE.ORG
Old 05-03-2014, 04:59 PM   #7
twogone's Avatar
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 05-03-2014, 07:32 PM   #8
Bummer man. I hate to hear it. I have no idea what a v6 might cost but my 5.4 was pretty pricey, over $4k to have someone do the job. Perhaps you can find a salvage yard engine?
Old 05-03-2014, 07:48 PM   #9
WVvan's Avatar
I'm doing the "Repair or Replace" internal dance now. I'm leaning towards buying another van at the moment.
WWW.WVBIKE.ORG
Old 05-03-2014, 07:51 PM   #10
Abitibi's Avatar
Seeing how much you love to modify your van it'd be tempting to get the 12v Cummins that UJOR has for sale... That'd be a sweet engine!
I really like what you've done with your van so far so I wish you a prompt recovery.
Cheers
Mr. D
2008 E350 Hambo
2001 E350 AmbuLand (sold)
1970 Econoline popup camper
1965 Econoline Travelwagon
Biggie
Berta
At-At
Dirk/co
