Old 07-14-2015, 11:23 AM   #11
UJOINT's Avatar
Re: 04 SMB w/our 4x4 conversion
Originally Posted by MadScience
Originally Posted by UJOINT
When we add the RSC parts to a non RSC equipped van it does't add the electronics, just the hard parts.
I'm curious why I'd want to do this. Is this basically future proofing the axles for a newer van?
Love the van, as usual! Not sure it's understated either.
Bigger brakes, elimination of unit bearings (99-04 axles only) larger stub shafts.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-14-2015, 12:08 PM   #12
E350's Avatar
(Talk about burying the lead...)
What are your thoughts about the benefits and detriments (if any) to "eliminating the unit bearings"?
Old 07-14-2015, 12:54 PM   #13
UJOINT's Avatar
Unit bearing get a bad rap, worse than they deserve in my opinion. Failures aren't as frequent as you'd think, and they're easy & cheap to replace. But, the cheap ones are what they are. Cheap. They certainly don't help the reputation.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-14-2015, 01:46 PM   #14
Ah yes, you have to replace the steering knuckles. I'm still considering this upgrade. Here's Oldbonesclimber's excellent write-up of the big brake conversion he did on the Dynatrac axle. viewtopic.php?f=3&t=6647&hilit=brake+upgrade
2011 VW TDI Golf for hwy fun
Old 07-14-2015, 07:01 PM   #15
Viva's Avatar
Originally Posted by rallypanam
Not sure a 6" lift with 35s is "understated", but it looks good..
Ha ha, fair enough! I guess it's the combination of "slightly restrained" Aluminess bristling, dark wheels, and the van colors.
Truly understated is my former '97 striped 2WD (Of course if there isn't anything to downplay, maybe it's not understated...)
Old 07-14-2015, 07:36 PM   #16
UJOINT's Avatar
Here's a walk around
[youtube:1mlm7qwp]
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-15-2015, 01:34 AM   #17
BajaSportsmobile's Avatar
Rotors are 02-04 F450/550. Calipers are 08/up E series. This kit pictured is from when we used to do both 8 on 6.5 and 8 on 170mm patterns. We just do 8 on 170mm now so the replacement parts are an over the shelf item.
Are you using the ~13 inch rotor or the ~14.5 inch rotor?
AgileOffRoad.com
Old 07-15-2015, 06:25 AM   #18
I agree with all that. I think the real bad rap comes from people ignoring all of the obvious warning signs, sometimes for thousands of miles, then get P.O'd when it locks up away from home.
Old 07-15-2015, 07:05 AM   #19
UJOINT's Avatar
14.5's
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-15-2015, 07:05 AM   #20
UJOINT's Avatar
True!
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Turtle
rafeman
Agnes
alta825
