Originally Posted by Twoxentrix
@rroberts76, Been wondering if you managed to resolve the issue of front hubs not engaging ??? Peeked my interest when you initially posted, and have been curious about the actual cause.
Where did I leave off? Took it to the shop, got new Warn Premium Hubs, they put them on. Before I left their driveway, I got out, locked the hubs, put it in 4WD, and slowly rolled forward, after about 5 ft I heard a CLUNK: no more 4WD. The Warn housing failed at the snap ring groove. The older Warn hubs looked like they had more material. Shop bought a new pair but was worried they would also break. So I drove the van home.
After some internet sleuthing and hub edumacation, I bought a pair of Dynatrac Dynaloc hubs and decided to install them myself. Pretty damn sure I removed all of the Warn Hubs, but when I assembled the DynaLocs the first part is a spacer ring, then a plate that the Outer Lock rides on. Either the spacer is too long (~.008" compared to their specs), or the axle (Dynatrac Pro Rock 60) is too short, with the result that the small snap ring groove on the axle is not exposed and I couldn't install the axle snap ring. Talked to folks at Dynatrac, they said its very possible that the axle is too short and that the snapring isn't critical and recommended installing without it.
So I did. Got them both in (same on both sides), tested them out, and they seem to work. I haven't taken them off road, so don't know how they will handle the abuse (maybe try Assateague this weekend). The spacer ring protrudes into the spline area of the hub and I'm a little worried about wear there. I asked Dynatrac if I should get the spacer rings milled down (~0.050") but haven't heard back yet.
So, like boats, there's two material conditions: broke, or in the interval between breaking. I'm in the interval now, hope it's a long one.
Interested to hear any other similar problems/solutions.
RR
