02-14-2022, 12:12 PM
I've been running the pro-comp 22415 spring pack on my 2013 EB with stock hangers and they have been great so far. About $300 from 4wheel parts for the pair. Gave me approximately 7" of lift above stock and matches nicely with my MG kit giving a proper rake
02-14-2022, 02:29 PM
As I'm overdue for rear springs this topic interests me. Spending $1800+ on custom springs seems a bit steep considering my particular usage/application. I'll spend it if that's my only option, but using a more common/cheaper production spring would be fine by me, assuming the dimensions work out.
Obes: any chance you could take a picture from the side showing your wheel being centered? Also, could you measure from the center of your wheel/axle straight up to the fender? How long have you had those springs on your van, and how much have they settled?
02-14-2022, 05:49 PM
Procomp 22415
I've had them on about 6 months, they have settled a quarter of an inch. They are at 28.25" from centerline to fender lip right now.
02-14-2022, 10:39 PM
Awesome, thanks for doing that! I'll have to see how my current setup compares. Are those 35"s? It looks tall enough to not be a problem, but have you experienced any rubbing? What's your shackle angle like, still pretty close to vertical?
02-15-2022, 12:01 PM
Hmmm... now you've got me thinking. Your 7" lift estimate is pretty accurate. Your van sits 4.25" higher than my sagging springs with a 3" block. Though that's much higher than I want, now I'm wondering if a stock Superduty spring would provide ~3" of lift, based on your 4" lift springs providing 7" on the van?
It's funny how everybody and their brother used to have a Superduty, now I only have one friend with one, and being the newest generation (with longer springs), I can't use his for measurements/referrence.
02-15-2022, 04:41 PM
Anyone tried the superduty rear spring swap?
On my previous 1998 E250 2wd SMB I installed a new “generic” five-leaf pack from ATS Springs here in PA. Cost was something like $550 including new hangers and hardware. While not fancy like Deavers, etc., they rode well and gave a decent bit of lift. You might look into local spring places and consider going that route. You can kinda see the difference in the pic below; the white van has the new springs.
02-15-2022, 04:43 PM
Another view of the white van with the five-leaf pack.
03-30-2022, 07:42 PM
Originally Posted by carringb
SuperDuty springs are about 3" longer than 92'+ E-series springs. I had a set on my van for a little while (about a year). They mostly fit except I could see that under heavy spring compression the stock shackles interfered slightly with the hanger-bracket. My fix was just to upgrade to Sulastic shackles. They moved the axle back 1.5" which was fine for my drive-shaft, but might be too much on a lifted van. My main issue with tire-chain clearance with my dually fenders, so I ended up making a hybrid spring-pack using the 2 of the leafs from the Superduty pack and adding them to an E-series pack.
carringb, do you have a thread where you made the custom leaf spring packs?
03-31-2022, 05:57 AM
Sorry... I've never really gotten around to putting together any build threads
It's pretty straightforward though.
My donor leafs were from an F250. Both packs were disassembled, and the E-series pack stayed the primary pack. Below the longest and 2nd longest leafs, we just added "in-between" springs (2 per pack) taken from the F250 pack, then bolted it back together with a longer center-pin.
04-01-2022, 04:12 PM
#20
Just for comparison purposes. These are rear spring brackets for an econoline and a ford f350. I dont see how the front brackets would work on a van.
Top picture is the econoline, lower is the f350.
