Sky’s Offroad Designs makes a Superduty rear spring swap kit that fits OBS Ford trucks and also the E-series.
https://www.skysoffroaddesign.com/pr...13780083605570
Has anyone here tried this and if so, could you report on the position of the new front spring hanger? I’m concerned my SMB grey water tank will interfere. Sky’s says the Superduty springs are about 8 inches longer, which looks like it might be a go, but it could be tight. Would be great to see which set of holes in the frame are used.
I’m running Sky’s rear shackle flip (Thanks for the donation from forum member Unreg!). My goals are to get some ride improvement from the longer springs and hopefully I pick up a bit of lift from replacing my worn out stock pack.
