Minimum lift is 4” using a ujor leaf kit w/Dana 60 front straight axle. Even at 4”, you have to trim the engine crossmember a couple inches, and run wo/trackbar, which is the setup I have. If I had to do it over, I’d go 6” w/trackbar. With either, you want the ‘high steer’ option, which all but eliminates bump steer.
