Yikes, didn't think about the Deaver's making a difference on the fitment of the stabilizer. Sorry about that.
daveb, the U-bolts that hold the center bracket onto the axle tighten up where I don't think there will be any rotation. I just got back from three days of beating the snot out of this thing on some nasty dirt roads and nothing shifted on mine. The system is working great!!!!
When I talked to Skyjacker, I told them I was working on a custom build and couldn't give 'em a specific vehicle. I also had spent a lot of time on their web page looking over the installation instructions for every one of the kits they make. That way I was able to figure out which kits might fit. I just needed some dimensions for their U-bolts and brackets. The guy was impressed that I had done that much research and was very helpful. As I mentioned, he pulled some kits, measured things and called me back.
The kit I used works and fits great on the SMB suspension, but I guess maybe only with the Deaver springs. I'm sure it will work on the stock SMB springs before they sag too much and the clearance between the tie rod and springs gets too tight.
