Originally Posted by mgmetalworks
That's one of our earlier kits. Most likely one that was sold through UJOR since I never used textured finish on parts I shipped. There have been a couple simple updates since then... probably pre-2018.
The shock used with the kit is a Fox 980-24-677.
I would cut the bump stops off and switch over to these...
SSF-111-47 | SumoSprings Front for Ford F-250|F-350|F-450|F-550
Ok, I had the old stops cut off and replaced with those SumoSprings bump stops. Not seeing much improvement. The guys at the shop pointed out that there was not much space for up/down movement and offered to cut the bump stops in half....how does that sound? (and the van is parked sideways on an incline right now, that's why one side shows clearance and the other doesn't)
