I have 2003 EB with sliding door, new rims and tire 17 inch rims, 285 60 17 tires. I also noticed the front axle is 2 inches wider then the back,, so I called Quigley and she recommended a shop in Vegas that makes aluminum spacers, so I put 1 inch on each rear hub and Now my door won't open all the way. So after about a year I took my van back to Leap truck painting in Fresno and he removed the door and cut out a section so it would clear on the inside. Now it works.
I'd really like to make it Electric like the new vans, anybody have that done yet?
QUOTE=motovan_mn;301395]Hey everyone,
I've searched high and low on this forum for a definitive answer, so I'm hoping someone can come forward with some helpful info. We just picked up a real gem of a van, but the only "downside" is that it has a sliding door. In terms of our use case the sliding door is not really a detriment, other than potential clearance issues for larger rear tires.
Our plan is to send this van to UJOR and get a 6" lift on 35" tires. I know that MG and Weldtec make slider hinge extenders which should enable clearance for a full size Bushwacker flare. However it seems as though UJOR recommends against running their rear wheel adapters (converts stock 8x6.5" bolt pattern hubs to accept 8x170mm wheels). I know from past experience that econolines in stock form have a noticeably wider track width on the front. I've never lifted or put bigger tires on an E-series, though, so two questions for everyone here:
- Anybody running a full width rear axle (or stock axle with spacers/adapters) and a sliding door?
- If not, does anybody have any photos of their lifted/4x4 van with stock rear axle width and wider front axle width?
Yes, I realize this is vain, but if I'm going to dump a bunch of $$$ into a toy, I want it to look good!
*Edit* - I guess another reasonable question is this: am I correctly interpreting that Quigley utilizes the stock rear axle, so their vans presumably have narrower track width in the rear?[/QUOTE]
