Re: what is advantage of Atlas 2 over other 4x4 options ?
If you have a bad rear u-joint, you are still going to have to drop the drive shaft with either T-case unless you want it rattling around as it gets driven by the rearend.
Atlas is obviously a great T-case that will stand up to more abuse than the factory chain driven T-cases and has the advantage of lower ratios and front rear split.
All of which costs a pretty penny. Is it worth in on our vans? Not in my book.
AgileOffRoad.com
