Old 06-13-2020, 09:18 AM   #711
Fitz's Avatar
^^^^Hein,
I'm on it! You are right, it looks bad, thanks for pointing it out.
The black spots you see are me previously applying the coating you reference to the various electrical grounding screws SMB installed during the build. On my list is gathering up the grounds and running them all to the Blue Sea Systems 2300 bus bar that I have sitting on the workbench waiting for the appropriate time...
Once done I'll be sure to go back and coat everything that's visible from the outside.
Question: Any thoughts on what to use in the holes once I remove the various screws? I'm currently thinking of simply plugging them with SS threaded bolts.
For reference, here is what it looks like from the inside:
KN6BJX
Old 07-04-2020, 03:11 PM   #712
Fitz's Avatar
An Expensive Bit of MB Plastic...
The little plastic clip attached to the arm of the windshield wiper that is the end of the windshield washer nozzle broke....
A piece of black tape has been holding all in place for the past several months. Flint went in for his 3rd scheduled service last week so why not replace the (cheap little) part?
$21.41 out the door. Not so cheap, but I guess it's all relative....
It is Item 40 on the parts list screen shot in the first picture, the MB part number is shown in the second picture if you find yourself in need of one of these and want to order it on-line.
KN6BJX
Old 07-04-2020, 08:57 PM   #713
velo47's Avatar
Ours broke on my last trip, The duct tape makes aiming difficult. Ours should be warranty, though?
W3TAX
WRDZ686
2016 4wd 144" Sportsmobile Sprinter
2019 Chevy Colorado ZR2
2002 lifted & armored WRX wagon (sold)
velo47 is offline   Reply With Quote
Old 07-04-2020, 09:11 PM   #714
Fitz's Avatar
Cheap little plastic part exposed to the sun, this looks like something we will be replacing every 4 or 5 years...
Flint is a 2016 at 58k+, no warranty for us!
KN6BJX
Old 08-16-2020, 11:51 AM   #715
Fitz's Avatar
Snap Lock Spring, Water Inlet Spring, Fitting Retainer Spring, Etc.....
I'll start with a picture. As to the setting, think 95 degrees in the middle of the afternoon, north of Mono Lake off 395 in CA on the east side of the Sierra, me holding the hose in one hand and taking the picture with my cell phone in the other after finding the source of the problem....
What you are looking at is the failed Snap Lock fitting located on the bottom of the radiator on the passenger side of the van. When this failed, it failed fast and it was a good thing that we saw the warning messages on the dash quickly. Our immediate reaction was to shut down the AC, turn on the heat, and watch the temperature display as we made our way off the dirt track we were on and got back to gravel. It's a good thing we were on our way back and were close to the road when this happened!
The immediate result was that Flint got his first tow, this after four years and 60+k miles of trouble-free service.
So what happened? I carry hose repair tape, hose clamps and enough water to fill the radiator, but my experience (before this) did not extend to this type of Snap Lock fitting. Think of a precision female receiver on the radiator with a matching precision male fitting on the hose, an O-ring in between and a three-sided exterior spring that holds it all together....
The van went to MB of Reno to be repaired. Good shop, I have no complaints with the service. According to them, they have never seen a failure of this type before.
Speaking to Dennis of Linden Engineering over on the Sprinter forum, he says this is something they are seeing back in CO on what is becoming a regular basis, and that the fault lies with the spring clip loosing its spring tension over time. He has started to replace the spring clip as a routine item every third service (the service Flint had about a thousand miles BEFORE this happened...)
From the MB Reno paperwork: "Found lower radiator hose disconnected. Reconnected hose, filled coolant, test drove, found lower hose slowly backing out of radiator and releasing coolant. Inspected radiator, found lower hose connection on radiator deformed. Drained coolant, removed air intake and grille. Removed and replaced radiator, lower hose and retaining clip. Filled and bled cooling system, test drove, confirmed proper operation".
Here is what both ends of the hose look like after the repair. Believe me, you have to look to find this particular attachment point! First the easier-to-see standard connection, followed by the Snap Lock Fitting connection to the radiator.
And here is the figure from the MB computer. The O-ring is item number 220, the hose is item number 200. Here are the part numbers:
906-501-20-82 A HOSE
000-993-08-02 A SPRING
Per Dennis, the spring clip can be changed from the exterior without disturbing the O-ring seal. Based on my use this is now something I will add to my regular maintenance schedule and this clip will get changed out every 3 years. I have a couple of them on order right now and one will be added to my on-board spare parts kit.
And here is a link to see what the offending spring clip looks like and costs:
https://www.mboemparts.com/oem-parts...ing-0009930802
All-in-all, this is just part of the experience and I got a nice train ride back and forth to Reno as part of it. But I don't want me, or any of you, to have to repeat the experience, thus I suggest we all learn more about this particular item and prepare accordingly!
KN6BJX
Old 08-16-2020, 02:54 PM   #716
Twoxentrix's Avatar
Unfortunate. Watching your own Van get loaded on a Tow-truck always heightens ones feeling of vulnerability.
Old 08-17-2020, 03:25 PM   #717
My condolences for Fitz. I just ordered the clips. I am profoundly grateful for the experiences and wisdom you share in a usable format. You have guided me on many aspects of the Sprinter and Sportsmobile life. Thanks. $2.74 clip. Cant imagine what a 2 and 1/2 tow cost.
salim is offline   Reply With Quote
Old 08-17-2020, 03:27 PM   #718
21/2 hour tow
Old 08-17-2020, 09:52 PM   #719
Fitz's Avatar
Originally Posted by salim View Post
My condolences for Fitz. I just ordered the clips. I am profoundly grateful for the experiences and wisdom you share in a usable format. You have guided me on many aspects of the Sprinter and Sportsmobile life. Thanks. $2.74 clip. Cant imagine what a 2 and 1/2 hour tow cost.
We all share the ups and downs and we are all better off for it.
Here's something else you will need to change out the spring clip:
The clip is removed from the top, you need one of these tools in order to hook the top of the clip, then pull it straight up. To replace the clip without disturbing the hose (and the O-ring inside it), carefully remove the old clip, then install the new one so that the tangs face towards the radiator. (Thanks to Dennis at Linden Engineering for the directions.) It will be three years before I do this, if anyone does it prior to that please report back on how it went!
KN6BJX
Old 08-20-2020, 07:50 PM   #720
tlg
tlg's Avatar
Fitz,
East Coast based rig and just had our 40,000 mile service performed at a MB Dealership. Brought up the failed radiator hose fitting/spring clip with the MB trained mechanic and mentioned that folks in CO were seeing this happen on a fairly regular basis. Said he has never seen that issue in his years of servicing both fleet and privately owned vehicles. He speculated that it could be prevalent out West due to the cold cycles and road treatments. We just don't see those extremes out here. Found his comments interesting given your comments above.
2014 Ford RB-50
Tags
carport, molding trim clips, recovery ramps, skid plates, suspension upgrade
Testing
Tech Admin
TumbleWeed
Sarah
