Old 12-15-2016, 01:03 PM   #1
illking's Avatar
Send a message via AIM to illking
03-07 Hood on 01
Will and 03-07 hood without ford emblem fit a 2001 E250 without modifications? Thanks!
www.thevanpires.com
2001 E250 RB30 Agile 4x4
1976 G30 Pathfinder 4x4 SOLD
illking is offline   Reply With Quote
Old 12-15-2016, 03:46 PM   #2
1der's Avatar
Should be no problem at all. Hang on to the old one if it is in good shape. Can be used for more hood vent experiments!!
Old 12-15-2016, 03:56 PM   #3
B350's Avatar
Yes, the newer hood sans Ford emblem is a direct swap as is the grill.
My van is a '99 and I swapped both the hood and grill.
'99 E350 EB 7.3L, 2WD, WeldTec lift, CCV Mid Top
B350 is offline   Reply With Quote
Old 12-15-2016, 04:22 PM   #4
shenrie's Avatar
just to add to others swapping experiences...
to achieve a shaved front end, i put a 95 grill (and composite lights) on my 03. i needed the headlight bucket from the 95 and it all just bolted right up. the 03 bucket wouldnt allow the 95 grill to bolt up properly. headlights were no issue with either bucket.
Old 12-29-2016, 05:59 PM   #5
Bbasso's Avatar
I really like the look of the fully shaved front end...
Rob.
Current:
And had three other E350s...
Old 12-29-2016, 06:57 PM   #6
All business up front, and a party in the back, just like a mullet.
Old 01-17-2019, 08:20 PM   #7
Anyone know if I can swap an 03-07 grill and hood into a 96? Is it a bolt on type swap for both?
Anything that I would need to do to the headlights...?besides getting better ones from vantage optics of course...
thescottgivens is offline   Reply With Quote
Old 01-17-2019, 09:35 PM   #8
It's a direct swap for everything up until they went to the new front end.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 01-17-2019, 09:40 PM   #9
Awesome thanks for the quick reply!
Old 01-17-2019, 10:47 PM   #10
rallypanam's Avatar
Not true*! There’s a couple different hoods where the only real difference is where the hood latch fits. It’s only about 1” different, but you need the right one.
*might be different year than OP mentions, I’m not clear on which ones are the different ones.
