Have this on an E350 i just bought. Alignment shop says its got a 3 deg Camber bushings and the knuckles are touching. Says anything less will prob result in the camber being out. Question is: This is a Ford Kit so why would Ford offer this kit knowing the truck could not be properly aligned? What am I missing? Thanks
Welcome to the wonderful world of twin I-beam suspension. As far as im concerned there are only two options when it comes to the Ford I-beam suspension. Leave it alone or get rid of it.
You only have two options...
#1 dismantle the knuckles and take a grinder to the area that is hitting the inner C in hopes of gaining a tiny amount of adjustment.
#2 have someone build you some radius arms drop brackets which will increase your caster numbers.
