Old 08-14-2015, 04:32 AM   #1
AC Freshwell 2000 in rear AC ventilator
I'm planning to install an Freshwell 2000 and have an idea of using the ventilator from rear AC that is placed in the roof.
Is this an bad idea ??
Micke
Tri-Star E350 Ext Wagon 2001 Powerstroke
heralue is offline   Reply With Quote
Old 08-14-2015, 04:42 AM   #2
Re: AC Freshwell 2000 in rear AC ventilator
You planning on tying in the unit to the vent via duct work on the roof?
How will you waterproof the unit?
It is 44lbs in a small package mounted on your roof that is designed to be mounted inside your rv
hogasm is offline   Reply With Quote
Old 08-14-2015, 05:54 AM   #3
The unit will be placed on the floor
Micke
Old 08-14-2015, 06:08 AM   #4
It sounds like a great idea. I see no problems. I wish I knew why those were not more popular here! Low power consumption, light weight, I see no negatives.
If I understand you correctly, you still have the rear air in the van, right? The Freshwell will just be tied in to the same ductwork and used when the van is off? If that's the case I don't see why it wouldn't work. Good luck and keep us posted.
Old 08-14-2015, 09:11 AM   #5
BajaSportsmobile's Avatar
Where will the heat be vented to the outside?
AgileOffRoad.com
Old 08-14-2015, 09:28 AM   #6
Looking at the pic it seems to vent through the floor.
Old 08-14-2015, 09:32 AM   #7
It might be difficult to find a good place to do that.
AgileOffRoad.com
Old 08-14-2015, 01:18 PM   #8
I will place it left side behind rear axle.
I think it will be posible.
Micke
Old 08-14-2015, 04:55 PM   #9
That should be a sweet set up
Old 02-26-2016, 11:35 AM   #10
Now I bought a freshwell 2000.
I will post pictures during installation.
Micke
