You planning on tying in the unit to the vent via duct work on the roof?
How will you waterproof the unit?
It is 44lbs in a small package mounted on your roof that is designed to be mounted inside your rv
It sounds like a great idea. I see no problems. I wish I knew why those were not more popular here! Low power consumption, light weight, I see no negatives.
If I understand you correctly, you still have the rear air in the van, right? The Freshwell will just be tied in to the same ductwork and used when the van is off? If that's the case I don't see why it wouldn't work. Good luck and keep us posted.
Re: AC Freshwell 2000 in rear AC ventilator
Where will the heat be vented to the outside?
Originally Posted by 86Scotty
Looking at the pic it seems to vent through the floor.
It might be difficult to find a good place to do that.
