Old 12-06-2013, 09:05 PM   #11
Re: Bed lining the side or rocker panels.
I Line-x'ed my whole Van and two toned it where the rockers are. Main color is Olive Green and the rockers are black.
2006 Express Duramax 2500
Spoolin is offline   Reply With Quote
Old 12-06-2013, 09:37 PM   #12
Originally Posted by WVvan
A question to those who've done this already. How do you feather the edges?
FYI - There is a special masking tape that has a wire in it that you can buy to do a clean trim of the material when you pull it off. It is expensive though.
PatO is offline   Reply With Quote
Old 12-06-2013, 09:42 PM   #13
on mine, I didn't feather any thing. Just sprayed on 2 or 3 coats and pulled the (normal) tape. But the stuff isn't as thick as you would think, or at least not as thick as a commercial type bed liner. I would say 1/16" or so.
Brew
tsbrewers is offline   Reply With Quote
Old 12-06-2013, 10:19 PM   #14
Viejo's Avatar
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
Old 12-07-2013, 04:06 AM   #15
Brand name or seller? This would be the perfect material for this job!
Old 12-08-2013, 05:55 PM   #16
Just got it back actually. Still have to go back for some touch ups but I think it looks good.
Old 12-18-2013, 11:58 PM   #17
Damn, where's the rocket launcher? Man If I was huntin and saw you coming I'd try to go the other way! Looks very cool.
Old 12-19-2013, 10:30 AM   #18
one of the rodder sites I follow has some info on using henry's elastomeric roofing paint for bedliner paint.http://www.crankshaftcoalition.com/wiki ... insulation
"What'$ that funny noi$e?
Old 02-20-2014, 05:10 AM   #19
Just bumping this back to the top to post this link: http://www.langeman.com/WireTrim
This particular brand and type doesn't seem prohibitively expensive---a few good videos maybe helpful to the DIY's.
Old 04-14-2014, 09:15 PM   #20
How did you guys prep the side of your van before applying the bed liner? I have seen trucks with the liner material on the rockers peeling off.
Also, anyone sprayed the conversion van style running boards/fender flairs? My van has these and the paint (gel coat?) is cracking and peeling the same way my penthouse is and it looks a bit crappy.
Has anyone had issues with these bed liner products not withstanding the flex in these parts?
jamesc is offline   Reply With Quote
