[QUOTE=86Scotty;327942] On an 06 I would replace the whole radiator if it were me.
At 110K miles I was going to finally change the plugs on my 1997 E-350 5.4L. As I started pulling the air horn off, the first thing I noticed was a cracker upper radiator tank.
Being someone who hates to redo work, I pulled the fan shroud and fan so I could change:
- tensioner pullies (bearings) I have since just adopted the practice of regreasing the sealed bearings which tend to come from China dry.
- New serpentine belt
- water pump
- radiator
and then more easily get to:
- Plugs (Motorcraft)
- COP (Denso)
- Injectors (eBay specials)
A basic tune-up set (Plugs, COP, Injectors)can be had for $200 so there is no reason not to freshen up the whole set. Of course, if you want to save some money (like the OP of my 2000 E-350 6.8L), you can let a mechanic diagnose a misfire problem and charge $750 to change a single COP
COP
https://www.ebay.com/itm/355013971382
Injectors (Pre 08)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 (I have a set to install right now; they look good but not yet tested. All other new options at $50 a injector)
Motorcraft Spark Plug - SP479X (this looks like the right one)
