Old 09-02-2016, 11:48 AM   #21
REDOVAL's Avatar
Update to the Move Bumper install....
I wasn't a fan of the light color and pattern of the OLB lights in the bumper we wired for aux reverse use. They were too close to a spot pattern and the blue color detracted from clarity.
I replaced them with Baja Designs Squadron Sport flood lights and the difference is staggering. The BD product quality is superb and their customer service is second to none. Highly recommended for all your led lighting needs.....
Baja Designs
Offroad LED, Dual Sports Kits, LED & HID Lighting | Baja Designs
(760) 560-BAJA (2252)
Scott
14232453_1282204695145044_7456731211403403159_n.jpg   14142076_1282204815145032_4253351821701884107_n.jpg
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 10-20-2017, 11:50 AM   #22
derJack's Avatar
Originally Posted by REDOVAL View Post
I'd guess it weighs about 75ish lbs with the lights. It's quite close to the stock bumper. As far as departure angle, it sits closer to the body and does have a more aggressive angle up, so I'd say there would be a difference. In all fairness, I never hit my factory bumper on anything offroad, at least to this point.
Edit, the difference in approach angle would be positive. This bumper provides more approach than the stock step bumper did.
Scott
The stock Bumper is way lighter!
I just measure, as its sitting around here: 15,60 kg or double + 10% - so 36 pounds. That´s the front bumper, the rear should be not much more.
derJack is offline   Reply With Quote
Old 11-23-2017, 07:30 AM   #23
mykdee's Avatar
I have a Hobart 140 Mig welder, do you think that would be enough welder to tackle a job like this?
mykdee is offline   Reply With Quote
Old 11-23-2017, 07:34 AM   #24
REDOVAL's Avatar
With proper beveling of the weld joints and the duty cycle of the machine respected you will be just fine. It's a really fun project!
Scott
Old 11-23-2017, 08:27 AM   #25
mykdee's Avatar
Scott
Thanks, I might have to tackle the job then!
