Old 07-27-2017, 08:35 PM   #41
That looks great! It should definitely last a long time. I think your brackets will still fit but they might cut into the liner. I've had them dig pretty good into stuff I've sealed gutters with. I would just check it out now and then. a bead of black silicone around the contact point might not be a bad idea either.
Old 07-28-2017, 06:49 AM   #42
woodbee's Avatar
Originally Posted by sdwindansea View Post
I got the roof fixed, a bunch of metal removal, welding, rain gutter repair, and the self leveling filler in the gutters. They then applied several coats of rhino liner to the roof. This was all done by the same person who did my last repairs. I would highly recommend them if in San Diego. I think this should last a lot longer than 10 years.
I still have to sand and repaint the awning brackets. I'm also keeping my fingers crossed that they still attach correctly as the gutter filler is thicker than what it was before, especially since the rhino liner was applied to it and over the lip of the gutter.
Really happy the repair work went well. I will do the same if my problem continues.
Thanks for posting the pics.
Woody
2009 White E-350 Modified EB-43, 4x4, 6.0 PSD
woodbee is offline   Reply With Quote
Old 07-28-2017, 11:13 AM   #43
Thanks Scotty & Woody. I'll post more info/pictures once I get the brackets back on. I agree that it probably will not be an issue. Have a great weekend.
Geoff
Old 05-24-2019, 12:58 PM   #44
gaffer's tape gutter fix
here is a picture of what 86Scotty was saying that Twogone did with the gaffer's tape that effectively creates a new edge for the water to drip off down the door as opposed to creeping down the underside of the gutter and then in between the seals and the door frame.....
hope this helps someone as much as it helped me!
choochee is offline   Reply With Quote
Old 08-05-2019, 08:29 AM   #45
oceansrealm's Avatar
I agree with most here that if you live in a coastal area especially, then you have to keep an eye on that roof. I have tried rhino liner and all sorts of paints on my repairs and have found that the most robust solution so far has been repairs with bondo an/or fiberglass then a generous coating of flex seal. The flex seal is extremely tough and provides a nice buffer to the rubbing of the pop top gasket. I also put a light coat of silicone grease on that pop top gasket to provide a bit of lubrication between the flex sealed areas and the top. The flex seal has lasted longer than anything else I have tried and seems to stop rust dead. Eliminate moisture and oxygen and you will slow the rust significantly.
I know there are way more solid fixes, but I feel like automotive paint does not stand up to the rubbing and the roof tape traps moisture. For a DIY solution I am very happy with it.
2000 EB50 4x4, V10
oceansrealm is offline   Reply With Quote
Old 07-31-2021, 10:23 AM   #46
BrianBlair's Avatar
Geoff
Hey Geoff-
Do you have contact info for the shop that did your rust repair? I'm up in Orange County but would gladly drive to San Diego for good repair shop.
Thanks,
Brian
BrianBlair is offline   Reply With Quote
Old 08-02-2021, 10:21 PM   #47
So my 1997 E350 had surprising roof rot around the drip rail caulking. Even though the whole body was pretty clean from rust, I watch the roof bubbling for some time before breaking down to repair. I was surprised how much rot was under the calling.
I did not do any welding but instead used waterproof shorthair fiberglass filler body filler. This is much stronger than normal filler and especially the red non-waterproof stuff. Generally, you want to put this on clean scratched metal (60 grid scratched by hand in crosshatch). However, you need to push the bond up inside thereof where it is rooted through and there is no way to get in there or even make sure you are selling it with the Bondo.
So I first did the recommended prep work for the POR-15, let it cure then sanded the area where the bond needed to stick and then the rest (which was mainly inaccessible) would just inherently be wedged in. It worked and the bond adhered very well where I was bare metal and where was pushed inside the roof it had enough mechanical grip from being pushed into the inside it was not going anywhere and everything was sealed. I painted the whole top with POR-15 and then coated it with the white roofing elastomeric paints (it is AZ) .
BTW if you need to repair termite riddled wooden doors and windows, then the waterproof bonds work extremely well. I use a two-part wood restoration epoxy to fully impregnate the wood first (turning to plastic) and then apply the waterproof Bondo.
Old 08-03-2021, 09:21 AM   #48
Am I missing something? I don't see any gaffer's tape.
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Old 08-03-2021, 08:12 PM   #49
It is hard to see in that pic. Basically you run a strip of really good duct tape/gaffer's tape or the like across the edge of something sticking only half of the width of the tape to the edge. Then you carefully fold it in half long ways adhering the half hanging off the edge to the other half which is stuck to the edge. This adds a lip to the edge and water runs off of it, keeping it from flowing back in to the door or whatever.
Reading this back it sounds more confusing than helpful. A better pic or video might suffice but I'm unable to help at the moment.
Old 09-08-2022, 01:51 PM   #50
bigriver's Avatar
Thread Revival
I've started the process of prepping to Monsterliner the pop top and roof. This is what I found under my corner rub tape. When the metal is pocked like this can I still mitigate further rusting without having it cut out and new metal welded in? If so any suggestions how to proceed appreciated. I've read this entire thread but still the question remains.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
