Originally Posted by oceansrealm
I have tried rhino liner and all sorts of paints on my repairs and have found that the most robust solution so far has been repairs with bondo an/or fiberglass then a generous coating of flex seal.
I agree
I have been using the fiberglass-reinforced Bondo for some time now. It is fully waterproof and very much a structural covering.
If one is extremely ana;l and has the skills, then go for it and weld in some sections of sheet metal. But if you properly treat the rusted areas, you can fully fill the drip rail and cover most any rust problems.
Even if you do need to tack weld some metal into an extremely rusted situation, it is going to be far easier to make it presentable with the Bondo.
https://www.amazon.com/762-Bondo-Hai...17306426&psc=1
https://www.amazon.com/Bondo-00277-G.../dp/B00PB3NTFO
So this Bondo is not as strong as a full expoxy glass layup but it doesn't need to be and it certainly will be much easer to final form.
As I read this thread I don't think people understand that what is causing the rusting is the dirt getting down into the OEM drip rail sealer. The water is washing it in there, but once the dirt gets it it is amazing how much it rusts even in a dry CA/AZ climate.
