Old 04-16-2020, 06:26 AM   #11
Originally Posted by gahamby View Post
Toad Jeep? How far can it jump?
Youtube is your friend. They can jump pretty high!
Old 11-12-2020, 02:05 PM   #12
b. rock's Avatar
I'm planning on this with an '01 WJ up on 35s. Kinda torn on a flat tow setup vs biting the bullet and getting a trailer. I'm assuming a trailer would pull far better?
b. rock is offline   Reply With Quote
Old 11-12-2020, 02:21 PM   #13
Flat tow will handle better than a trailer plus less weight. You will put more wear and tear on your tires and drive train, and you won't be able to backup.
Old 11-12-2020, 02:36 PM   #14
b. rock's Avatar
Huh, I would have figured the much smaller rolling resistance of trailer tires vs the significant rolling resistance of 35" M/Ts would have been a substantial factor.
Old 11-12-2020, 06:27 PM   #15
Orv
From what I've seen, how well a flat tow handles depends almost entirely on the steering geometry of the toad and how much slop there is in the tie rods, etc. If it wanders all over the road when you drive it, it's probably going to wander around when you tow it, too.
A minor consideration is traction. When you tow a vehicle on a trailer, you're adding the trailer's tongue weight to the back end of the tow vehicle. This gives it more traction. In a flat tow situation you'll be a bit more prone to spinning the rear wheels when you're on a slick or loose surface. On the other hand, if you're already near your rear GAWR you may not want the extra tongue weight adding to it.
N8SRE
Old 11-12-2020, 06:32 PM   #16
Yeah, but it's negated (and then some) by the extra frontal area of moving the jeep 2' off the ground, at least at highway speeds. But you won't hear the road noise of those M/Ts while it's being trailered, so there's that.
Old 11-13-2020, 02:14 PM   #17
b. rock's Avatar
Fair points. Sounds like I'll stick with the flat tow plan. Need to get the EGT gauge fixed first but that's a separate issue.
Old 11-26-2020, 01:57 PM   #18
DesertSMB's Avatar
Back in 1977 my dad and I set up to tow a 1968 CJ-5 behind a 1973 International Travelall 4x4 with 392 V8 (6.4 l). We traveled through Arizona and had no problems. The Travelall weighed in around 6000 lbs.
Chris
Chris/Bev
2012 E350 EB50 V10 Cruiser Top
Sportsmobile 4WD Conversion
DesertSMB is offline   Reply With Quote
Old 12-03-2020, 03:27 PM   #19
DosMars's Avatar
I've had the same idea for my '86 CJ-7... Interested in hearing how it comes out.
DosMars is offline   Reply With Quote
Dog hauler
DanaLynn
DADDOZR
REDOVAL
