06-06-2015, 09:54 AM
#61
Re: Trailer Project
Originally Posted by E350
Yep, that's what I am working on right now. I will be adding a stinger to my utility trailer's A-frame and welding on a Bullydog hitch coupler. which makes me wonder if I should be adding these to my completed projects:
http://www.amazon.com/Welding-Myself-St ... B00OX24SCW
No need to add the sign, one look at the welds on mine and it will be evident.
But, that said, my welds might be ugly, but I haven't had one break yet!
06-07-2015, 07:01 PM
#62
Re: Trailer Project
Heavy lifting is done.. Frame, rails, etc all welded and painted. Sheet metal sides and wood floor next weekend.. Then mount the jerry can mounts, propane tank, tie down points, and lights..
06-07-2015, 07:51 PM
#63
Re: Trailer Project
Beautiful!
(You are way ahead of me. I am still on chapter 2 of the The Procedure Handbook On Arc Welding, pub. James F. Lincoln Arc Welding Foundation... I think I will order this latest project book vol. V (it has 10 trailer projects) or all five of the project books published over the years for $43?
http://www.jflfoundation.com/ProductDet ... ode=AP%2DV
06-07-2015, 08:14 PM
#64
Re: Trailer Project
Looks nice all painted up!
Greg
New van: 2003 E250 EB10
06-14-2015, 04:25 PM
#65
Re: Trailer Project
#66
Re: Trailer Project
P.S. And some fenders, but that's going to be phase 2.
06-14-2015, 04:51 PM
#67
Re: Trailer Project
Originally Posted by rallypanam
... install the ipe floor...
Do you have sharp saw blades? I drooled over the idea of an ipe deck years ago, but everything I read said it was a nightmare to cut and drill.
06-14-2015, 05:03 PM
#68
Re: Trailer Project
Yes. But might need to buy a new drill bit or two.. I was going to use regular old pressure treated but 1der wouldn't let me, forcing me to buy some lightly used ipe for cheap.
06-14-2015, 06:50 PM
#69
Re: Trailer Project
Herb, we used lots of Ipe in our house remodel, both inside and out. Sharp blades and drill bits are nice. I found it actually is quite easy to work with. It is amazingly strong and has a beautiful tone. Make sure to coat the cut ends with Anchor Seal to prevent checking and splits. We did decks, balcony, vanities and even a shower curb/step. One thing to keep in mind is it is heavy and it is best to use a dust mask when cutting or planing.
Robb's trailer deck should look super sharp. Pressure wash and a maybe a very, very light sanding. When coating, only special ipe compatible coatings should be used as the stuff absorbes nothing. Worst things to use are varnish or oily type coatings. Just do not do it!! Use the good stuff - TWP Is a good one.
06-14-2015, 07:11 PM
#70
Re: Trailer Project
Sweet! Ipe deck will be cool also.......nice welds and paint too!
....makes me want to re-do my crappy trailer, but I have a van to finish first.
