Old 12-11-2016, 07:45 PM   #1
I need a stock 16" rim
I need a stock 16' 8 lug steel wheel for a second spare. I thought I would see if anyone in the PNW has one they would part with. Clearly, shipping would add up quickly, so hopefully it would be within driving range. Condition doesn't matter much, I just want a second spare. Thanks..........
Old 12-11-2016, 08:06 PM   #2
Glider's Avatar
I will have several after I convert to 4WD--that will probably happen in March.
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 12-11-2016, 08:14 PM   #3
shenrie's Avatar
I have 2 8x165 van steelies you can have.
Old 12-11-2016, 08:35 PM   #4
Jsweezy's Avatar
When you say 8 lug are you saying 8x6.5 or 8x170. I still haven't figured out what exactly that means to the masses because I've seen people use it both ways.
Either way I have 2 8x6.5 with tires (245/65/16 or something like that) that you could have if you want to make the drive to Portland.
Old 12-12-2016, 12:39 AM   #5
Not sure where your at but I have a couple extra steelies off my 1998 if you want one your welcome to it. I am in Utah so not sure how close I am to you.
"The problem with common sense is, its not that common." Mark Twain
1999 F-250SD XCab 4x4 5.4 170k
1998 E-350 LWB (Being converted now)
www.DirkMitchell.com
Dirk Mitchell is offline   Reply With Quote
Old 12-12-2016, 10:31 AM   #6
rallypanam's Avatar
Stock is 8x6.5.
Old 12-12-2016, 10:34 AM   #7
Jsweezy's Avatar
I know that but depending on the conversion stock could be E-series stock or F-series stock.
Old 12-12-2016, 11:16 AM   #8
Sorry, I should have been more specific. RPA is correct in that I need a 16X 8 X 6.5 which should be stock for my 2001 E250. So far it looks like Jsweezy is the closest to me at the moment, but it's still quite a drive. Still, I'm probably going to drive to Montana prior to Xmas, so you might not be that far out of the way. Let's see if anyone closer chimes in. Meanwhile, thanks to all so far..................
Old 12-12-2016, 11:36 AM   #9
shenrie's Avatar
where are you and what part of Montana?
Old 12-12-2016, 11:41 AM   #10
Currently near Bellingham Wa, then I'll be driving to Missoula Montana by way of Spokane, then North through B.C. to Prince Rupert and on to Alaska after Xmas. With my history of flat tires, I think a second spare is a good idea.
Bullwinkle
austineats
Biggie
Berta
