2002 SPORTSMOBILE (Fresno) EB50
7.3 Diesel Quigley 4x4 Manual Pop Top
Super Well Equipped
Looking for a new home and
A SPECIAL BUYER
PRICE : $ 44,900 asking *(Read Through Please)
4.10 LSD Full Floater Rear Axle (new - just installed)
Cruise Control / PW /PL / power mirrors
Transfer Flow 46gal Fuel Tank
4 exhaust by Diamond Eye
Maintenance records and SMB Binder
Ford presale mechanical inspection - passed in all categories.
Pictures below and more pictures / video available
Current odometer reading 364,008 miles -
Well maintained,, runs great. Receipts Available:
All the Major services and replacements have been done,
@314K
NEW John Woods Transmission
@323K
NEW Turbo and Up Pipes
@327K
NEW All Injectors all replaced
NEW Glow Plugs
NEW Fuel pump
NEW Tank sending Unit replaced
@356K
NEW U joints all replaced
NEW Tie Rods
NEW Brakes all four corners (Big Brakes -front)
Mechanically sound and ready to reliably go.
Aluminess components:
Front Bumper with FOUR Hella Driving lights ( fuse needs to be checked)
Rear Bumper w Swing Arms and Reverse LED Lights
Driver Side Rear Ladder
Nerf Bars
Rear Swing Arm Mounted Box
Roof Rack w Solar mounted panels
Interior: 9/10 rating
All upholstery in excellent condition - No tears or stains, water marks. Seats show light wear
Cabinet faces (Custom) well cared for
StarCool III Rear AC blows cold
CRL FW904RS Awning windows one each side. Excellent operation.
Factory Leather Wrapped Steering Wheel
Front Seats: Grey Leather
Power Driver seat
Swivel Passenger
Protective Seat Covers included
Big Fridge 3.1 Cu Ft. Norcold EV-441
Microwave
Big Inverter Freedom 458 Model 20 w Heart Interface Remote
40 Door Galley by Sportsmobile
Basement Box
Door Shades Day/Night pleated for all windows
CO sensor recently new
Interior lighting
LED bulbs in reading lights
Flourescent Lights on ceiling
Holding Grey water Tank
Motion Detector exterior light
Pop Top Bed Length 6ft on 2 panels
AC only Hot Water approx.. 3 Gals
10 gal Water Tank
Systems / Operations: 9/10 rating
NEW Pro Comp 17" wheels x 5
NEW Nitto Ridge Grapplers 285/75 x 17 ( less than 500 miles)
NEW Ram 3500 Big Brake up front, All new Brakes Rear
NEW Dana 60 rear axle FF LSD, 4.10 (less than 50 miles on it)
Warn Winch M1200 - wired plug in remote
Quigley Round Trailing arms update
Extreme Aire - Onboard air (Frame mounted Driver side)
Factory tow hitch and lighting connector
Tekshonka Brake Controller
Shore Power Cord
4D House Battery Lifeline GPL-4DL about 4 yrs old. Always on charge or solar 12.8 volts resting
Fiamma F45s 10ft Awning (currently not installed) w Bling My Rig Z Brackets
Ford Idle Controller
Pop Top Lift Assist Motor and Pole
Canvas in very, very good condition no tears, windows clear, no mold
Bushwacker Flares
Solar 2 x 140 W Kyocera Solar panels wired in parallel.
Solar Boost 3000i Solar Controller
Overhead Console
Smart rear View Mirror with temperature and compass
Exterior ??/10 (exceptions - see below)
All doors, door bottoms, rockers, side metal body panels, under the hood cross braces, underfloor surfaces look great or very good.
Frame and front suspension show the typical surface rust / patina.
All extremely sound.
The rear Full Floater axle is new (replaced OEM Semi Float) and was refurbished and painted prior to installation.
EXCEPT
Roof where the Pop Top seal rubbed through the paint and moisture was trapped under the rub protection tape. (See pics). These roof rust areas were not readily visible before pulling up the tape. Once the tape was pulled up it was apparent that this was going need substantial repair. The tape residue line can be seen in the pics. There are a few blister spots on the Driver side of the van near the Aluminess ladder. There is an area at the lower Driver to Fender area that shows surface discoloration and rust.
Interior inspection shows all interior areas and cabinets are in good condition. There are no signs of water leaks on any of the interior surfaces or upholstery from the roof holes.
THE REST OF THE STORY
This rig was going to be this familys retirement rig with plans to keep it for a very long time. They purchased this rig about two years ago.
The 7.3 engine runs great, the John Woods transmission was installed (by prior owner) 45,000 miles ago, all great. Shows well cared for. No tears, cabinets are in excellent condition. Steering is tight. NEW upgrades- tires, wheels,
NEWFull Floater 4,10 LSD rear axle, rear Deaver springs,
NEWFOX shocks,
NEW brakes all round including Big Brake Fronts, etc. A very well equipped, very sharp looking, and reliable rig.
After all these upgrades and update efforts, the owner decided to address a couple of small rust spots on the roof where, what he has come to learn, is the typical pop top rub the paint issue. He pulled up the black hard rubber protective tape and found the horrible nightmare of rust through in more than one location. He has not been able to find a shop local comfortable with doing the repairs with a pop top present. Reluctantly, with his very demanding work, and family life, there is no time for them to get this repaired. At this point he and his wife decided to let this go. So, with full disclosure, it is up for sale and looking for a buyer who can see the opportunity to get the roof spots repaired on this otherwise very solid rig.
WHAT IS NEEDED:
A buyer who wants:
*A very, very well equipped 7.3 genuine Sportsmobile Quigley 4x4 EB50
*An excellent running rig with tons of updates and upgrades
*AND has resources to have the roof properly repaired to their satisfaction.
Clearly, the roof needs to be properly repaired. Likely, the pop top does not have to come off but the canvas needs to be detached at the bottom so the rust can be dealt with. Then apply Raptor or Rhino lining on the repaired roof.
The van has been and is currently stored in a garage so there is no chance of rain finding its way into the interior.
Sway bar bushings could be upgraded to polyurethane bushings.
Remount awning after roof repairs
Power Driver seat is not functioning, needs troubleshooting.
EVERYTHING ELSE IS DONE.
Interested Parties:
The seller has asked me to help him with this sale and wants the buyer to know what they are getting - GOOD and BAD. I will field all initial inquiries to help answer questions and pass on serious/qualified parties to him.
I have not personally seen the vehicle but have conducted multiple video calls/walk throughs and asked every question I would ask if I were buying it as a very knowledgeable buyer. I have three vans now, otherwise this would be a consideration due to ALL of the other mileage related issues having been addressed.
ROOF PICTURES:
