Old 02-20-2024, 11:21 AM   #1
WTB: Ford E series captain seat bracket
Hello,
I have been searching for the bracket that bolts to the floor at my second row to attach the captains chair. My rig is a 2003 E350 chateau. Ive called ford dealers and junk yards all over with no luck. Does anybody have a bracket or a lead on where I may track one down?
I attached a photo as a reference.
Thank you!
Brandon
DonnyBoy553 is offline   Reply With Quote
Old 02-21-2024, 08:18 AM   #2
I ended up finding mine on FB, of all places. Not FB Marketplace, but on one of the Van For Sale groups. Not sure if you have the seatbelt situation figured out, but I've been having the hardest time finding a seat belt receptacle that is compatible with my 2013 belts.
Unfortunately I think the captains chairs and brackets are pretty desirable and in high demand, so when one shows up it goes quick. You've got to be diligent and quick to act.
https://www.facebook.com/groups/2858560497592796/
https://www.facebook.com/groups/639008852959721/
motovan_mn is offline   Reply With Quote
Old 02-21-2024, 09:31 AM   #3
Right on, thanks for the info.
Luckily I have the factory seats and seatbelts that came out of the van. I either never got the mounting plates or misplaced them years ago. I think I was able to find a plate online.
Also good to know they are so sought after, I only have space for one, Ill put the second one up for sale.
Thanks again,
Brandon
Old 02-24-2024, 05:00 AM   #4
spurious's Avatar
What side are you needing? There is a RH and LH side….
spurious is offline   Reply With Quote
Old 02-24-2024, 07:30 AM   #5
Aren't the two brackets identical? The seat installs from the passenger side for both.
Old 02-24-2024, 12:41 PM   #6
Yeah Roger that, I'm needing both plates. I found a drivers side plate and it arrived just now, I'll see if the pass side fits on it. Whats weird is some places online show it as two different part numbers which would indicate they are different to me, the passenger side plate is 2-3x as much money also. The ford dealer in my town is certain its the same part side to side...
Old 02-24-2024, 01:08 PM   #7
Center to center on the RH/passenger side pins are 11-1/8", LH/drivers side C-C is 11".
I found the drivers side plate also, thanks for the help.
Old 02-24-2024, 08:08 AM   #8
spurious's Avatar
As I remember trying to swap the seats they wouldn’t mount correctly???
I believe that is done so you can’t swap seats and have the ability to run without a seat belt…
Old 02-24-2024, 05:52 PM   #9
Ah excellent point, I stand corrected
Biggie
Berta
ClifFord
EliMakes
