Hi Herb,
So the wrappon is proving to be more of a difficult install that anticipated. Im being a bit uncommital on its mounting location and holding off a bit on moving forward with it wall mounted for now. My thoughts is that I'll likely relocate my telescopic ladder thats mounted along the wall and use that location. It may take some kind of aluminum flat bar mounted to the Wrappon to give the hinged L brackets somewhere firm to grab ahold.
Regarding the toilet itself it's a great unit. It withstood some -15 temps inside the van when my espar failed and it was able to still operate and heat seal the waste bag. For me that was a good sign of its industrial application from other industries. Wrappon is supposed to have some kind of bio plastic coming out soon as well - as in this year. I haven't followed up on that yet.
Biggest drawback is the set up - which is really not that big of a deal unless you've really gotta get to business. I have found myself setting it up in camp and putting it in the pass through walkway of the van under the lower bed and pull it out when needed. I can't say ive used it more than 6-8 times though so i'll hopefully put it to more use this coming summer and report back.
The other mods i did to the van was the new 20gal central water tank that was relocated inside behind the chest fridge. Black anodized aluminum case around the resevoir. Stronger pump, backlit water gauge, and a central fill from the front passenger cabinet. Really liking how that came out and will get some pics up here soon. That was performed by Rhune racing. THe pump is a bit loud so i'll have to make some adjustments. I also wired in a light strip in the horizontal driver side cabinet where the bath and hot shower set up are starting to take better shape.
Lastly my little new kickass oven is pretty sweet. Takes a bit to heat up but sips power and gets hot. It'll cook all kinds of small tasty items: muffins, biscuits, cookies, pot pies, small pizza's etc, etc. Definitely recommend. I got the aftermarket mounts for the oven as well - for those interested make sure to get those. Kaon brackets.
Glad your really thinking all this out, Herb. Worth the time and will make the build go smooooth....hopefully.
Sounds like you are maybe drifting from the ambo and thinking truck camper? I vote ambo for the record!
Any further insight or opinions on the Wrappon? If I go with a truck camper, or an ambo, it seems a nice way to "go" (pun intended).
